Hi all, since yesterday I am getting an error "unable to load channels", using kodi 15.0 beta 2; on both my pc & android phone. was working up to the night before. What am I missing, am I the only one?
Its down right now
PVR Stalker does work, it does require a longer timeout to connect. You can change it manually in its settings.xml file in the userdata. Don't bother asking me how to do this, because if you can't you probably shouldn't mess with it.
lol,,,,,,, c'mon dara, show me puleeeeze, you're such a helpful person always. Don't keep this one secret
It's not that it's secret, it's just potentially dangerous to the health of your Kodi install. On a PC, the Kodi working data in the "special:" folder, usually "c:\Users\<user name>\AppData\Roaming\Kodi". Your add-ons are in the "addons" folder, your add-on settings are in the "userdata\addon_data" folder. Just find the pvr.stalker folder there, and edit the "settings.xml" file with notepad.
I see what you mean by "dangerous". I did everything above, just not sure how/where to save it after & do I have to increase the range also. Thank you, I'll just leave well enough alone for now, don't want to break anything.
Ok, found it, I was looking in the wrong "kodi" folder, thank you much dara.
Ok, so this is what i got....
<settings>
<setting id="custom_mac_1" value="false" />
<setting id="custom_mac_2" value="false" />
<setting id="custom_mac_3" value="false" />
<setting id="custom_serial_1" value="false" />
<setting id="custom_serial_2" value="false" />
<setting id="custom_serial_3" value="false" />
<setting id="device_id2_1" value="" />
<setting id="device_id2_2" value="" />
<setting id="device_id2_3" value="" />
<setting id="device_id_1" value="" />
<setting id="device_id_2" value="" />
<setting id="device_id_3" value="" />
<setting id="parental" value="false" />
<setting id="password" value="0000" />
<setting id="portal_mac_1" value="" />
<setting id="portal_mac_2" value="" />
<setting id="portal_mac_3" value="" />
<setting id="portal_name_1" value="NFPS" />
<setting id="portal_name_2" value="" />
<setting id="portal_name_3" value="" />
<setting id="portal_url_1" value="http://localhost:8899/channels.html?portal=1" />
<setting id="portal_url_2" value="" />
<setting id="portal_url_3" value="" />
<setting id="send_serial_1" value="false" />
<setting id="send_serial_2" value="false" />
<setting id="send_serial_3" value="false" />
<setting id="serial_number_1" value="" />
<setting id="serial_number_2" value="" />
<setting id="serial_number_3" value="" />
<setting id="server_enable" value="true" />
<setting id="server_port" value="8899" />
<setting id="signature_1" value="" />
<setting id="signature_2" value="" />
<setting id="signature_3" value="" />
</settings>
Now what do i have to change?
dara clearly wrote=Just find the pvr.stalker folder PVR.STALKER you found pvr iptvsimple
