then fire stick should work if you get keyboard going on it
Amazon Fire TV box, USB keyboard with touch pad mouse. Got everything installed getting the portal and channels/movies loading however black screen when I try to play. I have MX player installed but not sure where to change the defaults. So close just need a little help. When I go to settings in the portal it gives me a Error emulator core initialization failed.
Settings does not work- you need to run the mouse up to the top of the screen to get to settings there. Long pause on a touchpad and maybe a double-click too will bring it up.
please let us know if you got it going
I was trying last night to bring up the settings from the top pop up menu and could not even tried a mouse. At work right now but will be trying again. If I understand correctly I still need to go into the settings and select the default player MX?
To setup mx for my devices, it's the menu button on the remote that brings that up. Will have exit there too
i have my NYKO PRO paired! trying to add google store with chrome,downloaded 6 files.explorer under tools gives me error,failed, root explorer: this feature cannot run on devise,(explorer is off in blue box,cannot find place to turn on)!any help would be appreciated,thanks.
yes,trying to install google play store
can you be a bit more specifique, nyko pro that's keyboard mouse?your trying to push google play? and chrome browser to the amazon fire tv or stick?
My dog chewed my remote which is why i'm using the keyboard and mouse. Nikon pro is a controller with a menu and back button I think.
Got it!!!. I had to use the FireTV app. Then pressing menu brought up a media player menu in the lower right corner. I selected external player, restarted. Then when I went to play a stream it gave me the option to pick my media player. I picked MX and then always.
What I was doing wrong before was going to the top pop up menu as I did not have a menu button using the usb keyboard and mouse.
Pretty happy with the FireTV box thats for sure.
