Page 3 of 42 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 418
  1. #21
    works great on the mag250...........thanks
  2. #22
    you can try on avov go to channel store go app tv online load app hit run load the info and see if you get green arrow if you do your good to go only on vod try it this way and see if it works
  3. #23
    TV Addicted toyz4tv's Avatar
    Not working here on avov.. App un installed then reinstalled. Still no go. Had tried another server last month and worked fine.
    If someone finds a solution, please let us know.
  4. #24
    Ambassador DarkSide's Avatar
    with the mag 254 although the url says
    http://1.iptvprivateserver.tv
    , you dont have to put the http:// if front of it and it will still connect.. try that with the avov
  5. #25
    Canada
    Testing with Mag254 ( @25mbps download) from Ontario Canada ... It's flawless ... Amazing picture.
    Can't wait for the whole package.
    Great work boys.
  6. #26
    getaddicted jetta's Avatar
    Testing with Mag254 working well!!
  7. #27
    Android World
    Working very well here thanks for the hard work guys.
  8. #28
    Avov set-up
    -Install TV Online APP from Channel Store.
    -After install complete and in that same screen, click on the RUN option.
    -Next screen, highlight a Server slot and click it.
    -Enter URL exactly as shown below...
    1.iptvprivateserver.tv/
    -Use the NEXT key to exit the keypad.
    -Skip down to the Connect option and click on it
    -The screen will change and you'll see the Server highlighted and in that same highlighted box, off to the right side, you'll see a circle. That circle will be green when connected.
    -Once green and if you then get a popup message that says something about a http header update, do not accept that, cancel it.
    -You should be good to go now. Open the VOD menu
    *You can also skip the RUN option and leave the Channel Store and go into your APPS and open that TV Online APP and do the connecting from there (same procedure).
    *red button -*please refer to post #51
  9. #29
    Thanks Guys!! Great picture though at first was working perfect now it seems to lag or buffer been testing different movies.
  10. #30
    Working good, testing on amazon fire tv and service is running well, i wouldnt say its hd but the reason for that might be the emulator and not the service i will compare side by side with the mag254 when ill get it
    Last edited by Goldyflix; 01-06-2015 at 03:49 AM. Reason: Missing some information
  1. SUPER BOWL SUNDAY ! Will IPTV be ready ?
    By Johndoe in forum Chit Chat Lounge
    Last Post: 02-07-2016, 11:54 PM
  2. Replies: 4
    Last Post: 02-05-2016, 05:12 PM
  3. NFPS VOD IPTV is ready!
    By tinieBlax in forum IPTV Talk News & Announcements
    Last Post: 07-14-2015, 10:20 AM
  4. new and ready to learn iptv
    By turbosmog1 in forum Introduce Yourself
    Last Post: 05-25-2015, 04:40 AM
  5. Ready for IPTV!!
    By speedymmx in forum Introduce Yourself
    Last Post: 01-09-2015, 04:53 AM
