Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Aug 2020
    yes I do
    Channels Freezing
    Are anyone else channels freezing? Been freezing for the last half hour or more. Let me know if anyone else is going through this and let me know how to fix it. Any help would be appreciated.
    Thanks, p.n. guin
    what box, app, setup are you using? no issues so far using buzz devices.
    Aug 2020
    yes I do
    Nvidia shield, IPTV smarters pro, IPTV rocket. Was working all day then just froze up
    Jul 2021
    Quote Originally Posted by pnguin View Post
    And what's your download speed at the box?
    Aug 2020
    yes I do
    My speed is 75mbps
    My speed is 75mbps
    try to reboot your network and device then try if that helps.
    Aug 2020
    yes I do
    I've reset my Internet and my box still freezing. It comes on for a second then freezes. Shit even my porn doesn't come on
    Jul 2021
    My speed is 75mbps
    What speed do you pay for?
    do you use vpn? if not try with vpn might be isp related?
    Lots of freezing around here also. More so on UK channels. I have 1GB speed and I'm using the Kokaleka app in a Sonny android tv
