Results 1 to 10 of 12
Thread: Need help
    Aug 2016
    Need help
    Hi friends
    Again need help....I order 5 routes 12 months iptv66 and not receive it. Someone can help or resolve the issue
    Jul 2021
    How is it even possible that you can login to to this site?
    Just a big WOW.
    Aug 2016
    Nobody help ??????
    Check with Ryu and Crazed might check in soon...?!? Hang in there, if You didn't wait til the Routes have Run Out, All should bee OK thru the system...!!
    My bet is that the Routes probably have arrived
    Aug 2016
    Send me a private msj crazed pls
    Quote Originally Posted by Cesar1982 View Post
    you don't ask Boss to send you a message.
    Rocket Recovery Technician
    The first thing to check is if your payment went through, next if you want help just tell the date, service and pay portal you used. NO PERSONAL INFO OR NUMBERS ON THE FORUM if they need it THEY will PM you for it. GOOD luck!!! If you do everything right it should be like clockwork every time.
    Jul 2021
    Quote Originally Posted by 12icer View Post
    http://iptvtalk.net/search.php?searchid=6133064
    vBulletin Message
    Sorry - no matches. Please try some different terms.
