Results 1 to 3 of 3
    Apr 2017
    help choosing a mag box from infomir
    I am working with mag 254 from infomir
    what other models of mag box's from infomir will work
    with programing = iptvprivateserver.ru
    Papiao
    Thanks. for your Help
    The Mag devices are not androids, they run on a Linux Operating System and so they use firmware /middleware for functionality, unlike other iptv devices, which run on an Android OS and which utilize Apps for iptv and other functions.
    Your Mag does not use Apps, cause it's not an Android.
    That 254 most likely has the Stalker Middleware onboard.
    Most all mag boxes came with the Stalker until a few years ago when infomir changed from Stalker to Ministra Middleware.
    So now all Mag devices from infomir carry the Ministra Middleware. Well there are a couple exceptions, which are their Hybrid models, which are Androids, but there are only one or two of those models and may be discontinued now.
    So to use a Mag device you'd need a server that supports Stalker or the more recent Ministra.
    Papiao now does that
    Click the link for more info
    http://iptvtalk.net/showthread.php?4...pport-Ministra
    The specs for each Mag device will be listed at infomir's website and will show if the OS is Linux or Android and will also show if the middleware is Stalker or Ministra (both middleware are compatible with papiao).
    *Sorry about the lengthy explanation for a simple thing, but now you may know more then you may have before
    Apr 2017
    Thanks for your help
    I got the picture now very helpful. I have a better understanding now.
    Thanks for your help.
  1. If you are seeing a looping after choosing the MediaPalyer Home Screen
    By crazed 9.6 in forum BuzzTV XR/XRS4000 - XR/XRS4200
    Last Post: 06-04-2020, 04:34 AM
  2. Help in choosing a good IPTV with panel
    By saberpavo in forum IPTV Private Server (NFPS)
    Last Post: 01-03-2017, 02:42 AM
  3. Mag 254 from Infomir
    By Drew60 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 12-28-2015, 09:01 PM
  4. Advice on choosing NFPS or Rocket: Pros and Cons
    By tvgeek in forum IPTV Private Server (NFPS)
    Last Post: 08-15-2015, 03:19 AM
