Bob Benjamin’s Aeronca Model “K”
(1/4 scale), with a wingspan of 108”
A total of 357 were built beginning in 1937
Stinson Reliant Yellow-Blue (220cm, 7kg, 30cc) CYMODEL
Balsa Wood Airplane Kit Micro 3CH 378mm Fokker Eindecker by DW Hobby; Remote Control Balsa Wood Laser Cut Plane Fokker E for Adults;RC Un-Assembled Flying Model for Fun (K0801)
Carl Goldberg Anniversary Addition
Stock Number: GPMA0963
Cub Wingspan: 76.5 in (1943 mm)
Clipped Wing Cub: 67.5 in (1715 mm)
Cub Wing Area: 744 in² (48 dm²)
Clipped Wing Cub: 648 in² (42 dm²)
Wing Loading: 21.70 oz/ft² (66 g/dm²)
Flying Weight: 7-7.5 lbs (3.2-3.4 kg)
Fuselage Length: 48 in (1219 mm)
Requires: .40-.61 (2-stroke) or .70-.90 (4-stroke) engine, 4-channel radio, 4 standard servos, two rolls of 6-foot covering.
A Big Thanks to NBS, Buzz team, IPTVTalk and Farmer1...!!!
MAMBO RC AIRPLANE KIT FROM OLD SCHOOL MODEL WORKS
Specifications:
Wingspan:44 inches
Wing Area:365 square inches
Length (airframe only):42.75 inches
Weight:2.5-3.5 pounds
Radio: 4 channels
Hint
1. I am an outdoors kind of man so I do this hobby outdoors. It can be done indoors on a smaller scale.
2. I'll start of cutting it down to 3 hobby's fire arms, motor bike or Remote control.
3. Lets remove motor bike
4. I only do RC planes
5. I'm not into war birds
6. This one is a stick built kit. I bought it used so I didn't have to build it.
7. This is a scale plane. So the size is what scale it is to the original plane.
8. This plane was designed as a trainer. It is a high wing plane
9. They where built in the 1930 and 1940
10. The plane has been named but not the correct scale /wing span
Everyone's time is set to 0
Two of the greatest qualities
to have in live are:
PATIENCE
and
WISDOM
Stinson Reliant SR-9
SPECIFICATIONS
Model type: Sport Scale ARF
Skill level: Intermediate builder; intermediate/advanced pilot
Wingspan: 100 inches
Wing area: 1,497.6 square inches
Airfoil: Semisymmetrical
Length: 71 inches
Weight: 17.6 pounds
(1/8 scale), with a wingspan of 54”
Comet Aeronca K Floatplane - 25 inch Wingspan Flying Balsa Airplane :
