Results 21 to 30 of 34
Thread: No Guide for me
  1. #21
    I think theres nothing wrong on acid side. looks like papiao changed from tvg_id to tvg-id is causing issue. I maybe wrong but that is what im seeing difference this time. so people with hard copy should do like last time Remove - from tvg-id to tvg id and it might work. im not front of it to test for couple days but if someone got chance to test with hard copy let us know.
    So I was able to test this.
    On a hardcopy I changed tvg-id to tvg_id ... but it doesn't seem to make a difference. No acid epg
    I will double check my findings but does not look like this will work
    Jul 2021
    Wouldn't AJ have to make the changes?
  3. #23
    thanks for testing bro. which device did you test on? so it might be acid side or both. I made changes on my x5 and nothing. tomorrow I will test on 4900 and see if that makes any difference. also. should be tvg id without dash or underscore
    thanks again for testing bro
  4. #24
    when we modified last time acid did not change anything that time. not sure if he adjust anything after but im not seeing anything difference from his url data like last time. but I did see difference on papiao side little change. so thats why im thinking it might be papiao side or both.
  5. #25
    Bulletproof
    I just hope Papiao can adjust it back so we can get our EPG guide from acid. Thanks for letting us know and testing it crazed. andkaal
  6. #26
    I was using the buzz X5
    I used the underscore, but if you tried just with the empty space then prolly no need in me trying.
    Last time the changes were made in the server URL in XC API Mode, and not in EPG's URL or data
    Remember, it was the tag at the end of the server URL.
    Quote Originally Posted by andkaal View Post
    I don't know if papiao even knows we are having problems. It would have been cool if we could have found the reason as Ryu may have, then we could take that to papiao.
    yes I tried that and no need for you to try but I will test on 4900 soon for verification.
  9. #29
    I created a new m3u slot and used the server's EPG URL (shown below) and the server's EPG working (with no changes to the EPG data).
    So then I loaded the m3u playlist with the data change as Ryu outlined, except I used the underscore still because that's the file I had onboard. The EPG is also working with this edited copy (with the data change).
    So that change of data may not mean anything, or not
    And, the X5 is capable of showing the EPG thru m3u hardcopy, so we know that works on the X5 side.
    http://p1.iptvprivateserver.ru:80/xmltv.php?username=XXXXXXXXXXXX&password=XXXXXXXXXXXX
    no luck on 4900 either
  1. Replies: 2
    Last Post: 09-03-2016, 11:50 PM
  2. Server 4 guide issues on Avov (missing all uk channel guide info)
    By SebsiBC in forum IPTV Private Server (NFPS)
    Last Post: 04-19-2016, 07:56 PM
  3. Guide stop working channels work no guide
    By Tata123 in forum PVR Clients
    Last Post: 04-12-2016, 02:27 AM
  4. Server 4 guide issues on Avov (missing all uk channel guide info)
    Last Post: 04-10-2016, 04:21 PM
  5. Stalker Client 0.8.3 and EPG Guide Program Guide Time Issue
    By MitchL in forum IPTV Private Server (NFPS)
    Last Post: 10-17-2015, 01:57 PM
