Results 11 to 20 of 34
Thread: No Guide for me
    I had no guide on my buzztv today. so I went to server settings and changed from xml epg to server epg then hit clear epg and all load fine.
    I think theres nothing wrong on acid side. looks like papiao changed from tvg_id to tvg-id is causing issue. I maybe wrong but that is what im seeing difference this time. so people with hard copy should do like last time Remove - from tvg-id to tvg id and it might work. im not front of it to test for couple days but if someone got chance to test with hard copy let us know.
    thnx Ryu. I will test on that later this evening ... nascar is on and then off to work, but will get to that later to see if you are indeed correct.
    My money is on you
    hope acids will work but atleast server epg working for sure.
    Bulletproof
    Thanks for getting Ryu. I don't know how to do this with Kodi in Fire tv sticks. Just hope papiao fixes it back to were it was. Or aCID can make a new EPG Guide. I know they are doing a maintance as it says in forum for the next few weeks. This is what could be the problem. Thanks again my friend. andkaal
    JOKER Tha Joker's Avatar
    Sep 2016
    Quote Originally Posted by andkaal View Post
    I haven’t used kodi for IPTV in awhile. But in the settings there is a spot to clear guide data. Not sure if it will help but it is there
    I dont use kodi bud. I use buzz boxes only bro as they are the best and easy to setup. but I do have epg from server using buzz. unable to test modified hard copy as I dont have direct access to boxes for few days but I did compare my last modified copy vs new copy and thats the only thing I see difference but this may not work this time as it could be papiao side or acid.
    Sep 2016
    System
    settings
    pvr & live tv
    guide
    clear data
    not sure if it will work. Gonna test it out
    Sep 2016
    Acids guide isn’t working for me either with IPTV simple client. Gonna try acids with some different apps
    Bulletproof
    Thanks to all who got back. Hopefully it can be fixed. andkaal
  1. Replies: 2
    Last Post: 09-03-2016, 11:50 PM
  2. Server 4 guide issues on Avov (missing all uk channel guide info)
    By SebsiBC in forum IPTV Private Server (NFPS)
    Last Post: 04-19-2016, 07:56 PM
  3. Guide stop working channels work no guide
    By Tata123 in forum PVR Clients
    Last Post: 04-12-2016, 02:27 AM
  4. Server 4 guide issues on Avov (missing all uk channel guide info)
    Last Post: 04-10-2016, 04:21 PM
  5. Stalker Client 0.8.3 and EPG Guide Program Guide Time Issue
    By MitchL in forum IPTV Private Server (NFPS)
    Last Post: 10-17-2015, 01:57 PM
