Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: No Guide for me
    Bulletproof
    Unhappy No Guide for me
    Is anyone having a problem with no EPG guide when getting on to kodi ?? All 5 of my donations have not been working for the past 3 days. They were all working for years and now no "EPG program guide". The channels come in fine. Just no guide ?Thanks andkaal
    are you getting the guide from the server or from acid's EPG ?
    Bulletproof
    aCID's. I have been using it for many years. andkaal
    could be acid is working on it maybe. I lost acid's guide awhile ago but that had to do with my STB ... so I cant test it for you bud
    Bulletproof
    Thanks for getting back crazed. Hopefully that is the case working on a update. andkaal
    so I hooked up another STB which works with Acid's guide (thru m3u connection method) and I immediately got an on screen message saying that the XML EPG could not load
    Srever's guide loads thou thru XC API connection method on the same STB
    mmmmm
    Bulletproof
    mmmmm
    Is that bad ? andkaal
    TV Junkie 1sikguy's Avatar
    Apr 2016
    Limbo
    I have been down for 2 days on KODI as well...
    I sent a message to AciD, but I don't think he can do anything,,,
    Just have to wait till it gets resolved ..
    yous could use the server's EPG but only till acid's is back on for you.
    Acid's is always a better EPG but it's always nice to have options.
    Devices will allow more then one server to be added. One with acid's EPG and one with Server's EPG, then switch between at will.
    Don't know how that works thru Kodi apps thou
    For the Server's URL, use the one shown below but change the server portal to the one you use and the X's with your credentials (username/password).
    Server's EPG
    http://p6.iptvprivateserver.ru:80/xmltv.php?username=XXXXXXXXXXXX&password=XXXXXXXXXXXX
    Bulletproof
    Server's EPG
    Much thanks crazed for the response. Will try it later. andkaal
  1. Replies: 2
    Last Post: 09-03-2016, 11:50 PM
  2. Server 4 guide issues on Avov (missing all uk channel guide info)
    By SebsiBC in forum IPTV Private Server (NFPS)
    Last Post: 04-19-2016, 07:56 PM
  3. Guide stop working channels work no guide
    By Tata123 in forum PVR Clients
    Last Post: 04-12-2016, 02:27 AM
  4. Server 4 guide issues on Avov (missing all uk channel guide info)
    Last Post: 04-10-2016, 04:21 PM
  5. Stalker Client 0.8.3 and EPG Guide Program Guide Time Issue
    By MitchL in forum IPTV Private Server (NFPS)
    Last Post: 10-17-2015, 01:57 PM
