Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: My Best
    Dark Horse
    Jan 2016
    yes I do
    Can I Install APKTIME App Without Any Issue ❓
    Quote Originally Posted by worlok15 View Post
    if its compaitaible and download from good source then you should not have any issue.
    Dark Horse
    Jan 2016
    yes I do
    Thanks Ryu 👍
    Jul 2021
    Thanks Ryu 👍
    Use App Store(Aptoide) and it will let you know.
    Dark Horse
    Jan 2016
    yes I do
    APKTIME Is NOT In Aptoide
    Jul 2021
    That's because Aptoide is an APK installer.There's no need for another unless you want problems.
    In BuzzTV We Trust.
    Rocket Recovery Technician
    The only programs I have found that are not compatible are the for the older versions of Android, and those that will alter your system files.
    The box will run any good safe app, You can force load some others but I would not suggest it, why cause problems with a great box just because you want a program that you liked on something else.
    I tried a lot of the older programs on the U5 but they did not work as well as the ones supplied and I am running a lot of storage space, I can transfer a large movie from the DL folder to removable storage almost instantly and the DLs are mostly around 30 seconds to a couple of minutes for really large ones Most are under a minute.
    This thing is like a McLaren P1 vs a 6cyl Mustang.
