I am trying to use the stalker client and the iptv app on kodi on my fire tv box and it will stall some and buffer then play for a minute then kick me out of kodi back to the dashboard on my fire tv.
I have the same issue, the stalker pvr client is unstable.
Both the pvr client and the app does the same.
strange, mine works perfectly fine.
which server are you using?
thats weird app works on my stick
I have it on fire stick and works great.
Mine works perfect too!
Please check the Kodi version that you are using.
Also Check the version of the IPTV Stalker Client.
Another great addition to your Fire Tv toolbox is the WOKUNG Remote Control App for Mobiles that let you sideload apps from your Mobile and also emulate a Mouse on the Fire TV. That will help you with Sideloaded Android Apps that require mouse support (Eg.: Spotify, @TV Belkin and others.)
Good Luck!
