Results 1 to 4 of 4
    Jul 2015
    Does anyone else is having problems with iptvrocket servers
    Does anyone else are having problems with iptvrocket? Mine is down and I get the message of (the host not found) but my internet and wifi are working find. Please let me know
    Quote Originally Posted by jose angel View Post
    did you check your rocket at the rocket website ?
    Ensure everything is ok... including the server URL... at rare times that URL may change
    Jan 2015
    You using
    P2 or P1
    Must match your papiao
    Rocket Recovery Technician
    If you are using a VPN, try to link with it off for a second, If it connects, disconnect reset the area you are linking from and start the VPN again and try it. Some paths refuse to connect to a VPN, if you keep having trouble try an obfuscated VPN path. It is most common if you use a dual path VPN to have a not found problem.
  1. p1.iptvrocket.ru is down for me
    By ulpi in forum IPTV Private Server (Rocket)
    Last Post: 08-27-2021, 11:48 PM
  2. Problems s1 and s2 servers
    By antvar in forum IPTV Private Server (IPTV66)
    Last Post: 09-23-2018, 07:14 PM
  3. p1.iptvrocket.tv
    By franknitti in forum IPTV Private Server (Rocket)
    Last Post: 10-12-2017, 08:42 PM
  4. 22.iptvrocket.tv
    By pitboss in forum IPTV Private Server (Rocket)
    Last Post: 09-07-2016, 07:03 PM
  5. is iptvrocket down?
    By rmartes in forum IPTV Private Server (Rocket)
    Last Post: 02-15-2016, 10:01 PM
