Results 1 to 10 of 12
    Mar 2017
    dark side of the moon
    ppv trouble with buzz 5 not working
    is there a way to watch ppv that works is the question.
    seems like every time I clear the cache first and try to watch ppv I get the error msg that buzz 5 quit working.
    also a second question: for ppv is there a pause/ play option or fast forward anywhere?
    thanks
    Jul 2021
    Quote Originally Posted by shadow View Post
    thanks
    How often are you clearing cache?
    Your remote has those functions.
    Warrior
    are you getting the message at other times or just ppv?
    the ff rewind etc dont work on the ppvs
    You can set up timeshift for ppvs to use those functions
    Mar 2017
    I usually dont have trouble with buzz 5 not working unless I am watching ppv channels. It never seems to make it all the way through and I have to start over again so thats not good.
    I just clear the cache ahead of time when watching ppv since I have trouble most all the time.
    have no idea how to start the movie back up where I left off using timeshift. Sounds interesting though.
    Warrior
    You turn on timeshift in pvr settings and assign storage
    Jan 2015
    I noticed new update on time shift on tonight’s beta update !!
    I never used time shift yet
    Your saying you can time shift Ppv movies ?!?
    Quote Originally Posted by Rinny View Post
    with papiao service Timeshift will work with secondary player on PPV movies but movies won't play because media format not supported. movies will play with default player but Timeshift won't work with default player.
    Warrior
    Ppv movies work with both players on mine I am currently watching ppv 5 on secondary and I am able to pause and rewind
    Warrior
    After watching ppv for a while I rewound to beginning then fast forwarded to where I left off
    Buzz xrs 4900 version 5.0.653 unable to play PPV's movies on secondary and unable to pause or rewind. other than that works fine on all other channels.
  1. Buzz Sales - Buzz Home
    By crazed 9.6 in forum All the Buzz
    Last Post: 12-15-2023, 08:24 PM
  2. Buzz 5 quit working
    By shadow in forum BuzzTV XRS4900
    Last Post: 12-20-2021, 12:44 PM
  3. Replies: 300
    Last Post: 03-21-2018, 11:47 PM
  4. Replies: 650
    Last Post: 03-03-2018, 01:14 AM
  5. new hd trouble
    By godassassin in forum PVR Clients
    Last Post: 04-10-2017, 08:27 PM
