Results 21 to 30 of 35
Thread: buzztv2
  1. #21
    site rules violation
    been there they advised me to ask here.
    OK, how's that working for You w/o Updating again...?!?
    when i uninstalled updates my iptv started working again but there is no option to select tv series and other options are missing.
    anyway i have now installed tivimate on the box and all is working great, just a pity i cant use the buzz app which is all i wanted to do.
    only help i seem to get is buy a newer box.
  2. #22
    At least You can do what You want Now with that tivimate and You don't have to buy another box, for now that is... This stuff is always changing, that's why it's called "Testing"...!!!
    Quote Originally Posted by normski2 View Post
    That is incorrect.
    That box is an android and so there are many many options that can be had to make it useful as you need or want (like that tivimate app)
    We here at iptvTalk are not technicians working for buzz team. We are here to give suggestions or 'possible' fixes only.
    This is another reason why we post tutorials and info on such things like available android apps, like that tivimate.
    Believe it or not we spend many hours researching and testing things to see if they may be good enough to post here at iptvTalk.
    Pretty sure the tivimate is one of those things.
    We also have our own revamped Android app for papiao iptv and yes for TV Series too
    It is posted in a sub-forum on our main board here at iptvtalk
    That app would also work on your buzz 3000 box
    Anyway, there was some help offered to you here for your situation, but as we see there is not further support for this box and so we can not miraculously fix something that is unfixable due to the fact that the team is not releasing anything new for that box or whatever the reason may be.
    You were not ignored, we did try. But as I said we can only go so far.
    It's an Android thou and being an Android there are 1000 ways to make it work.
    Lots has been posted on this site.
    I have an old android I still use on occasion and it has not been supported for approx 6 or 7 years now, but I do like that particular box for one reason or another and so I make it work the best it can work with help from 3rd party applications.
    And about support. If the Buzz team or any Team continued support for their old boxes then they would go outta business because all their time and efforts would be dedicated to these older boxes with older and out dated software and or apps.
    There is not one box-maker team that does things differently. Some will support a box a little longer then others but relatively speaking, they all do the same thing and it is neccassary or they'd be outta business. They need to make and sell and support NEW boxes or we can say goodbye to them. Simple as that.
    - Frank Zappa
  4. #24
    Jun 2015
    Off The Grid
    Had one
    didn't love
    sold it.
    this box would be perfect for me if the support was there.
    very very poor from buzz
    guess i'm wasting my time asking any more for help.
    shocking
    what stb did you sell ?
    just curious , you said you didn't love it and sold it .
    what is " it "
    your post sounds <>< E
  5. #25
    bought a xrs4500
    but i prefer the 3000 box
  6. #26
    @ crazed
    i don't think i was asking for the impossible.
    it would have been better if when i first asked for an earlier version of buzztv2 for someone to just say there isn't one.
  7. #27
    @ crazed
    I thought that what post number 2 says
  8. #28
    https://buzztv.com/updates/
    DO NOT Quote this post unless the link gets [Coded] in that Quote...!!!
    @ryu
    After buzztv 2 there’s buzz 4 and 5 and it’s available on newer buzz devices.
    where in your answer does it say there are no earlier versions?
    in fact ryu don't even bother answering as all your input is USELESS at best.
    as ive posted found a solution now.
    dont need the buzzshite app.
  10. #30
    i factory reset box but didn't help.
    eventually i uninstalled updates from buzztv2 and bingo it's back on.
    when i update back to latest version it stops working.
    your first post said clearly that factory reset did not help and uninstalled updates from buzztv2 and bingo. so what someone should give you between factory installed and update that did not work for you? of course buzz4 or buzz 5 that is next available right? is not that what I told you? maybe you dont want to accept that and here to bash our sponsor and that not gonna happen here.
  1. Weird channel loss issue after BuzzTV2 app Update to v2.0 (211)
    By jropps in forum BuzzTV 3000 series models
    Last Post: 01-01-2019, 10:47 PM
  2. Buzztv2 apk
    By red556 in forum BuzzTV 3000 series models
    Last Post: 12-29-2018, 02:01 PM
  3. BuzzTv2 app version, Android version & ROM update or Build - explained
    By crazed 9.6 in forum BuzzTV 3000 series models
    Last Post: 06-29-2018, 01:47 AM
