Results 1 to 10 of 11
Thread: No sound
    Nov 2016
    Promise
    No sound
    Anyone else having issue with either dreamlink t2/t3 or formuler z8 with no sound on channels. So far I’ve found 302 304 305 306. Video users fine just no sound. I’ll update as I find more channels.
    yea, some them channels have no audio.
    I thought I found it was mainly the channels with Spanish descriptions.
    I wonder if changing the default player will help?
    I think I did try that with no luck
    Nov 2016
    Promise
    How do you switch the default player with the boxes listed above
    while on LiveTV channel or VODs, use the menu button to bring up the side bar menu, then in the Settings > Configuration should be the option. You might have to scroll down in that menu to find it.
    You might need to stall other Players or Player, if you do not get the choice.
    Mar 2017
    Cant seem to be able to do it. Using Dreamlink T2 Prime Dol2.
    Quote Originally Posted by angelc View Post
    I can not say for sure ,but if memory serves me you can only change to an external player while in the VOD selections with the dreamllink devices.
    I don't think you can if on LiveTV channels.
    Someone will have to confirm that thou.
    This sound issue has to do with a decoder, Some Players or devices will also have that option, but prolly not on the T2
    Quote Originally Posted by R2D2 View Post
    The audio works, it's a decoder issue with the player you're using. I don't know what player you're using, but in mine i went into the settings and went into playback. I switched the audio decoder from Hardware to software decoder. That fixed it.
    Mar 2017
    Thanks crazed. I’ve been reading and seems to be on all 3 services. Just noticed today channel 180 (freeform) had no audio and it was working fine. When i hit options and check audio track, it doesnt load. All channels seem to be running on aac 0.0. Few hours later same channel started working fine. I feel its server wise giving “factory iptv app” issues like dol2 imo. If this doesnt get fixed soon, which i hope, what can dol2 be replaced with thats really similar?
    Jan 2015
    Sound fixed !!
    cool beans
    Don,t seem to have sound on channel 202 . Been down for a while on the sound . Using a XRS 4000. Just that one channel. Any one else?
  1. Replies: 1
    Last Post: 03-25-2024, 01:00 AM
  2. No sound
    By worlok15 in forum Dreamlink T3
    Last Post: 05-22-2019, 07:15 PM
  3. How to get the best sound from my OTT
    By two-dogs in forum OTT M8 4K Android TV Box
    Last Post: 02-11-2017, 04:54 PM
  4. My T1 has no sound ?!
    By montell in forum Dreamlink T1
    Last Post: 05-24-2016, 05:42 AM
  5. HDMI video with no sound/// Cinch cable with sound but no video
    By Dino in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-27-2015, 11:03 PM
