Results 1 to 10 of 10
Thread: buffer speed?
    Mar 2017
    dark side of the moon
    buffer speed?
    just curious what buffer speed is mostly used on buzzz 4900
    have decent download speeds over 150 down
    gigabyte modem
    good router
    wired connection
    bluerigger cat 6
    have tried using nord vpn with no difference that I noticed
    running iptv66 at the moment
    still feel there must be something else to try
    What about clearing cache ?
    Below is an expatiation as to what that buffer setting actually does
    http://iptvtalk.net/showthread.php?3...ghlight=buffer
    what that buffer setting does may not be what you think.
    When the stream is interrupted for what ever reason, the box goes into buffer mode, which means that it will pre-load the up-coming content or try to (it creates a 'buffer' zone).
    If the buffer is set at 10 then it will preload 10 seconds of content before it tries to access the stream again. If it is set at 2 then it preloads 2 seconds of content before it tries accessing the stream again.
    That is just a generic explanation of how that works. But as you can see, setting at a higher value will then tell the box to automatically per-load for that higher time before the program resumes... setting it lower would help with less buffer time, if the interruption is only a temporary thing.
    However if the interruptions are constant then setting that buffer value would not really help with it being a higher or lower value....
    Only reason to have that value set high is if you have super slow internet speeds and want more content preloaded before viewing than you would get more time with uninterrupted viewing once it starts again and till the interruption may occur again.
    Setting it at lower value with normal to high speed download speeds, would help with less buffer time and still get uninterrupted TV viewing because the content is loading faster then it is being viewed.
    Think of it this way... if an interruption happened but only lasted 2 seconds, but you have your setting at 10 seconds, then your box will still buffer till that full 10 seconds are pre-loaded, even thou the stream would be okay before the time it takes to load them 10 seconds. So a lower setting is the way to go with a correctly working server and or ISP (and of course ISP traffic is also a part of this)
    As I say, if the stream or ISP is faulty then none of this matters.
    - Frank Zappa
    I saw mootz fix his buffer issue awhile ago, so I looked and found the post....
    Quote Originally Posted by mootz View Post
    Hi everyone, I wanted to give an update to my freezing and sound issue's
    I have comcast and I use there router, so I've been looking for a VPN router for about 1 year to add on to my existing network.
    i have come across a GL.iNet GL-MT1300 (Beryl) VPN Secure Travel Gigabit Wireless Router that has VPN built into it, i get nothing for telling you this info.
    since i have hooked it up I get no freezing, tv works perfect just like it should. If I do get a freeze all I do is change channel and come back and its fixed.
    - Frank Zappa
    Mar 2017
    interesting read crazed and thanks
    Yeah usually ISPs router with a sucks and creates too many problems. Try your own router and you will be fine.
    Lightbulb
    Wow, they gots a Special Black Friday Deal(s) going on :
    https://store.gl-inet.com/products/beryl-gl-mt1300?_pos=2&_sid=13a11320b&_ss=r
    4me doesn't get anything for this Post Either... they Accept Major CC and even PayPal... Choose Wisely...!!!
    Rocket Recovery Technician
    It may be the distance you are from the providers node, Some providers use too few nodes and load them heavily, they also run the hookups too far and you get losses in a high bit transfer. If you connect to a VPN you should set it up to connect to the fastest connection and use a P2P if it is available. There are so many things that can affect speed on any network. I always shut mine down and let it reset, I run a lot of old movie PD movie downloads so I am running high rates all the time a repop B?W is always over a G.
    Oct 2015
    vpn
    hmm a vpn built in, i assume you still have to pay a sub for one of those vpn?
    yes you have to pay for vpn service. vpn built in meaning it has functions to setup vpn service in it.
    look go ebay and get vpn for 5 bucks i didnt say that was told that now get your own router too that will for most part fix all i had to get new router because the one they gave me gave me circle of death i call it then i called the company they said that that router was cheap one to get better one so i did and for most part no problems at all i run fios hope that helps you i run frontier
  1. Buffer settings
    By Rinny in forum IPTV Private Server (Rocket)
    Last Post: 03-29-2022, 03:01 AM
  2. Replies: 0
    Last Post: 09-23-2017, 07:05 AM
  3. Buffer Setting?
    By Imp08ala in forum Dreamlink T1
    Last Post: 02-24-2017, 12:52 PM
  4. Buffer Settings
    By Petrucci in forum IPTV Private Server (Rocket)
    Last Post: 03-08-2016, 01:47 PM
  5. Buffer Settings
    By Petrucci in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 03-08-2016, 01:59 AM
