Results 1 to 10 of 13
    BuzzTV Essentials E2 Plus Specs
    Output Resolution: 4K (3840 x 2160)
    CPU : Amlogic S905X3 64-bit quad-core ARM® Cortex™ A55
    GPU : G31™ MP2
    RAM: 2GB DDR3
    Storage: 32GB eMMC
    Operating System: Android OS 9 Pie
    WIFI: 2.4GHz / 5GHz Dual-Band 2X2 Wifi
    LAN: Ethernet 10/100
    BT: 5.0
    Video decoder : 4K@60fps, VP9, H.265(HEVC) , H.264(AVC, MVC) , Real , MPEG1/2/4 ,
    Video Format : TS , MKV , FLV , MOV , AVI , RM , MP4
    Audio Format : MPEG-1 Layer 1,2 , AAC-LC , HE AAC V1
    Image decoder : JPG , BMP , GIF , PNG
    Support Language : Global
    Length : 10.5cm
    Width : 10.5cm
    Thickness: 2cm
    Color : Black
    USB2.0 : 1
USB3.0 : 1
    MicroSD: 1
    Power Interface : 1
    Optical Audio : 1
    HDMI 2.0 (CEC) : 1
    10/100 LAN : 1
    Type : 5V 2 Amp Adapter
    impressive specs
    thnx for bringing to us Ryu
    I love the eyes of this Tiger
    of course really awesome specs
    One day we will have to gather up all these animals that BuzzTV techs are depicting and put them in an Ark or something
    yeah sure. great idea.
    Warrior
    not bad depending on the price of it, because it has more of the same
    WIFI: 2.4GHz / 5GHz Dual-Band 2X2 Wifi = ok can be better by adding wifi 6
    LAN: 10/100 Ethernet = ok can be better with gigabit Ethernet
    Video Format: TS, MKV, FLV, MOV, AVI, RM, MP4 = ok since many use this type of format but it can be better adding DRM HLS MPD
    this to say some things, it is time to improve all this and much more
    Jul 2021
    Quote Originally Posted by suport View Post
    This is pretty much an entry level box.For $100 you won't get much better.If you want better pay the piper.
    Warrior
    When you say (If you want better pay the piper) if you refer to one of its latest model, the (xrs4900) it only has one of the updates that i mention everything else is the same
    xrs4900 update
    LAN: Gigabit Ethernet 10/100 / 1000M = nothing else
    Jul 2021
    xrs4900 update
    My point is you expect a lot for $100.
    Warrior
    yes it is money jajajaja
    If you look in the forum there are cheaper devices and more or less of those same specifications and they offer more
    You told me check best box they have and it doesn't have anything different than that of 100 and big big down it still on android 9
  1. BuzzTV Essentials E2 MAX Specs
    By Ryu in forum All the Buzz
    Last Post: 03-13-2022, 09:42 PM
  2. BuzzTV Essentials E1 PLUS Specs
    Last Post: 01-03-2022, 04:16 AM
  3. BuzzTV Essentials E2 SE Specs
    Last Post: 12-03-2021, 12:41 AM
  4. BuzzTv Essentials e2 Specs
    Last Post: 06-30-2021, 09:21 PM
  5. BuzzTV Essentials e1 Specs
    By NBS in forum All the Buzz
