Results 1 to 10 of 13
    Yes I do
    Kodi 14.0 source add on box ... Fire stick
    Im new to Kodi I installed it with some other add ons, and they are working fine. I went to add another add on and when I went to the add on source box to type in my info I had the complete boxes but there were no letters in the box to choose from did I type in some where the wrong info? Right now I can't get any add ons because I can't type anything to get them anyone help me? Thank you.
    Pinball Wizard
    What device are you using? what name did you use at the bottom to save the source at file manager?
    Yes I do
    Fire stick
    Yes I do
    Not sure of name
    Pinball Wizard
    You go system>File manager>add source (type in sources), done >scroll below to enter name for this media sources hit enter and type name (ex: fusion, xunity) hit done, scroll to OK hit enter/ok button.
    Go to system>setting>addons>install from zip and look for file name and you can upload repos. once uploaded go to System>settings>addons>get addons>all addons and pick which addons you want.
    Yes I do
    I can't type any letters in source there are No letters in the boxes to type empty
    Pinball Wizard
    try reloading Kodi into the box again to see if it works.
    so its File manager>add source- click center circle then next says add files highlight the box that says none click center circle a keyboard comes up type in http with file name then go to net box type name of file just look at Laser915 post 5
    Yes I do
    When the keyboard comes up there are NO letters in the boxes bro this is my issue! But thanks for the effort.
    Yes I do
    I'm going to do that but not right now system is working ok just can't add Anything that requires any typing in source box. I'm going to purchase the new box comming out soon so I might never know what the problem or the fix is,appreciate the help though. Maybe I can help you out some time. Take care James.
  1. download kodi onto fire stick
    By hobbyman in forum Amazon FireStick & FireTV
    Last Post: 01-02-2019, 07:23 PM
  2. Fire TV stick crashing using Kodi 15.2
    By roboughton in forum Amazon FireStick & FireTV
    Last Post: 03-27-2016, 11:53 AM
  3. Putting Kodi on fire stick
    By dotsadie in forum Amazon FireStick & FireTV
    Last Post: 03-08-2016, 01:19 PM
  4. Amazon fire tv stick and kodi
    By Clowe in forum Amazon FireStick & FireTV
    Last Post: 02-04-2016, 09:30 PM
  5. Replies: 1
    Last Post: 01-27-2016, 02:54 PM
