Started feeling days ago
Buzz
4000
4500
4900
Sound loss on USA channels example
182 263
633 213 290 fine
Anyone else
Mag box fine
Buzz
4000
4500
4900
182 263
633 213 290 fine
Anyone else
Mag box fine
im not using rocket but on 4900 I have no problem.
are you using hdmi came with them? try different hdmi and see if it makes difference.
there was sound loss on a few channels last night. (iptv66)
TVLand would loose sound after about 10 minutes and then it would come back and the loop continued.
buzz box 4900 and iptv66
I am not sure how it is doing today thou or how other boxes are
added:
182 just lost audio 4900 (channel change brings it back).
Change to another device and seems the audio is fine.
I believe i remember that this happened awhile ago too. The channel change always fixed it,till eventually the issue went away.
Seems that when the server gets a micro glitch, it happens without noticing anything with the video besides maybe a glimpse of a freeze, but the audio is lost till a channel zap.
- Frank Zappa
Ya your correct I have many with the same problem it’s the server side 100%
That said it’s not affecting the old mag boxes or older 3000 Buzz boxes !! Other buzz boxes big problems
4000
4500
4900
Yes sir it’s a micro glitch not affecting video !! Just audio
182
263
Will not affect
290
633
And others
Mostly USA channels
Yea on default
Audio set up correctly
I have few dozen boxes the same thing and on different IP I know it’s the server !
Some channels fine most usa not
182 ok today or for now
300’s bad for sound loss
263 too !!
Edit
182 just lost sound up a channel back it’s corrected
Micro glitch caused. It
