Results 1 to 10 of 16
    Jan 2015
    p1.iptvrocket.ru is down for me
    I am using iplayTv on Apple TV but cant login it says login error today. I checked my rockets and they are just fine. Is the service down? appreciate any reply
    server should be fine, but I been wrong before
    The thing is thou that the server is very rarely ever completely down.
    I saw one report from another member earlier today , but that member has been having issues for some time, so not related here.
    Otherwise there been no others reporting it being down.
    Must be some other issue , which would be hard to guess from here
    Jan 2015
    Hmmm I tried changing full version http://p1.iptvrocket.ru/c/index.html but that didn't help either. Status on rocket is Active and I have plenty of remaining days. I guess no TV tonight
    Quote Originally Posted by ulpi View Post
    something to do with the ipalytv or Apple Player maybe ?
    Try logging out of it and back on again.
    Jan 2015
    It’s all up here !!
    Some sound loss tho I noticed
    Jan 2015
    Maybe is iplaytv or appletv will try old mag to see. Thanks for trying to help will report back as I need to run ethernet cable
    Jan 2015
    Ok old MAG is running fine. I also tried different apps for Apple TV but on every iptv app authentication failed. How can this be?!!! Apple TV is working fine on everything else hmmm
    when you switch from device to device you have to perform a reset
    Jan 2015
    Thanks Ryu, reset worked although I never had to reset just changing MAC worked but you nailed it thank you
    glad it worked
  1. p1.iptvrocket.tv
    By franknitti in forum IPTV Private Server (Rocket)
    Last Post: 10-12-2017, 08:42 PM
  2. log-in credentials for iptvrocket
    By crazed 9.6 in forum IPTV Private Server (Rocket)
    Last Post: 12-04-2016, 10:21 PM
  3. 22.iptvrocket.tv
    By pitboss in forum IPTV Private Server (Rocket)
    Last Post: 09-07-2016, 07:03 PM
  4. is iptvrocket down?
    By rmartes in forum IPTV Private Server (Rocket)
    Last Post: 02-15-2016, 10:01 PM
