Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Aug 2021
    Stbemu pro problem
    I am trying to get my stbemu to work. I have inputted a valid Mac address and valid url.i get the message to contact the administrator.
    The url and Mac are working fine. Help please.
    make sure to add /c/ in the end
    also, perform a reset on patios site
    also, if you were on p6 then change your portal on papio site to a different portal, then perform a reset there then come back to your box and change portal to whatever you have on papios site.
    Aug 2021
    I don't understand. My url is good, and the Mac is good. When I put in another Mac address, with same server it will not work. The Mac address is from my second Mag box that is working. Why will my stbemu not work with this address?
    do you perform a reset on papio site whenever you switch between boxes?
    Aug 2021
    What do you mean?
    if you have nfps, rocket or 66 one of these service then your allowed to connect one donation on multiple devices but one device at a time. whenever you switch your service to different device then you have to go to either nfps, rocket, or 66's sites and log in with your donation info and hit reset button.
    so if you are not hitting reset button then its gonna work on only first device you connected with.
    Aug 2021
    I do not use any of the above. I am using a private server. I have 2 mag boxes, subscribed and working. Only one will work with the stbemu. I then used a friend's mag box and mac address, and it too would not work ( same server ). Box is subscribed. Any ideas?
    Is the stbemu being used on one of these Mag boxes ?
    Are these Android Mags ?
    I ask because the stbemu is an emulation of the mag platform, so to emulate that on a mag would be kinda counter redundant
    Or another question is that if you are using a authentic Mag MAC with a stbemu app then that won't work. Well not with what I seen with servers.
    You'd need the variant .
    OMG not the variant !!!
    The MAC for an stbemu app may need to be what your server mandates and not the identifier 00:1a:79
    See what I did there?
    I used 'variant' and 'mandates' in a red heiring
    Aug 2021
    The server mandates the mac address on the mag box. It is a mag 324w. Should I change the mac addy on the emulator and use the same url?
  1. StbEmu
    By jose angel in forum IPTV Private Server (Rocket)
    Last Post: 08-26-2021, 05:02 PM
  2. Problem with STBemu
    By tehans in forum IPTV STB Emulators
    Last Post: 03-30-2018, 07:17 PM
  3. STBEMU Favorites problem and version check
    By JoeOfCola in forum IPTV STB Emulators
    Last Post: 10-12-2017, 06:27 PM
  4. StbEmu 0.8.07
    By K20R in forum IPTV STB Emulators
    Last Post: 09-07-2016, 12:42 AM
  5. New STBEmu
    By jumper in forum IPTV STB Emulators
    Last Post: 08-24-2016, 05:28 PM
