Results 1 to 5 of 5
    Jun 2015
    yes I do
    mag254 power line adapter
    I've been using 2 older Asoka 9650 power line adapters rated for 85mbps with another device and it was working fine. When I connected mag254 it was heavily freezing every 15sec or so. When I run cable directly from the router works perfect. Problem is that TV is in another room and I can't have cable on the floor. My question is, should I try different power adapters or go wireless ? Thanks guys for any suggestions. My int. speed over 50mbps.
    alphaaaaaaaaa alphablondy's Avatar
    wireless antenna for the mag is about 11 bucks that should suffice. i just found a user guide manual for your power adapter . i will send the link in message. see if you can figure it out.
    yea got my for 7 and works great look in ebay
    Jun 2015
    yes I do
    thank you guys will try that
    Warrior Member
    HTML Code:
    http://iptvtalk.net/showthread.php?1773-How-To-Use-One-Long-CAT5-Cable-To-Satisfy-All-Those-Network-Sucking-Boxes
  1. MAG254- wifi adapter not connected error
    By Phat84 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 04-21-2020, 04:37 AM
  2. Mag 254 North America Power Adapter
    By blackmajik in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 02-28-2016, 08:45 PM
  3. Burned MXQ box wrong power adapter
    By yamayer in forum Android TV Boxes
    Last Post: 01-04-2016, 05:23 PM
  4. Best wireless adapter for MAG254?
    By sweeterman in forum IPTV Private Server (NFPS)
    Last Post: 06-23-2015, 07:59 AM
  5. Any recommended Powerline Adapter to use with Mag254?
    By vashira in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 02-14-2015, 04:46 PM
