Page 38 of 38 FirstFirst ... 28363738
Results 371 to 379 of 379
  1. #371
    unbanned christmas
    Jul 2015
    Quote Originally Posted by Blackbear199 View Post
    system/tv/guide...default select action change to switch to channel.
    Didn't notice this. Great option. Thx
  2. #372
    Jan 2016
    OOkay everything loaded, channels updated, am i missing something, I don't see a guide or interface to watch channels with stalker nfps set up?
  3. #373
    Hmm, been up and running with rocket for a couple of weeks, no problems. Now a couple of days ago, everything loads as usual but only 65 or so channels appear. any thoughts?
  4. #374
    Quote Originally Posted by lennitard View Post
    Never mind... menu bar all the way to the left somehow got switched to "entertainment channels" not all channels..Duh
  5. #375
    Hi,
    i have kodi 15.2 running on android and went through the setup on page 1. I tried with Stalker Client NFPS and Stalker Client but i keep on getting an error message : unknown error "can't load DLL" using both addon.
    Also when i enable the Stalker addon, it gets disabled after an error message appears..
    I am comfortable with the setup since i did it on previous old version of kodi and worked fine. I cant figure out why i cant get it running following the instructions step by step.
    any help much appreciated.
  6. #376
    Dec 2015
    Yep
    Got the same on fire tv. The version number is 0.8.4 though? Any suggestions
  7. #377
    Jul 2015
    Ok. And final solution for non-root devices ? Like shield and ATVF2 my example.
    And continue dll error with the last 1-31-2016 ?
    Wait or buy another device ?
    Too short time for test the version 1-31-2016 !! IMHO.
  8. #378
    If Kodi isn't an option due to the dll problem on your android device and you can't root to fix your permissions, I suggest using the STB Emulator.
  9. #379
    I'm closing this thread as there is a separate tutorial on the EPG forum, and tutorials shouldn't be used for issues.
    http://iptvtalk.net/showthread.php?1...with-epg-ninja
    If you have issues with the **********, post in that forum: http://iptvtalk.net/forumdisplay.php?97-EPG-(epg-ninja)
    If you have issues with the pvr.stalker or pvr.stalker.nfps, post in this forum: http://iptvtalk.net/forumdisplay.php...TV-PVR-Simple)
  1. Replies: 5
    Last Post: 08-24-2016, 02:21 PM
  2. Replies: 6
    Last Post: 02-10-2016, 06:06 PM
  3. Replies: 390
    Last Post: 01-29-2016, 06:01 PM
  4. How do i get full EPG for Stalker ?????
    By pgonzalez in forum Amazon FireStick & FireTV
    Last Post: 07-10-2015, 09:03 AM
  5. Replies: 3
    Last Post: 05-01-2015, 05:02 PM
