Results 1 to 5 of 5
Thread: guide question
    Warrior
    guide question
    who has a guide? The units that we use to test have guide but I have none
    who else?
    thanks
    The xrs4000 on MAC portal currently has working EPG
    IPTV66, but that should make no difference as the EPG xml is same.
    Warrior
    i know other units do ,asking on the 4900
    if you wanted to do a 'test' with the EPG
    You could use the M3U server configuration and use the M3U Playlist URL and then use either Acid's EPG URL or Shooty's EPG URL
    Those URLs are fairly lengthy thou so I use Total Commander Manager which has the Copy function.
    I just went thru the steps on this XR4000 here, I know its not the 4900 but I wanted to ensure it does work with the Playlist URL and EPG URLs, and it does.
    Once I connect to that server slot, it seems to take some time to get started up thou. It hangs on 'Loading Move List' for at least one minute it seems.
    The guide for these procedure with Total Commander
    http://iptvtalk.net/showthread.php?4...otal-Commander
    The best is to use an attached mouse for this setup.
    If that works or does not work, may help in trouble shooting the issue at techs end. I do not know how,but there it is
    Might not be too many on site here with the 4900 model yet
    Warrior
    Delete
    Delete
    Delete
  1. Guide question about adults
    By Sharkfhin in forum IPTV Private Server (NFPS)
    Last Post: 07-24-2017, 07:57 AM
  2. Different kind of guide question
    By Supernoob in forum Dreamlink T1
    Last Post: 08-08-2016, 03:23 PM
  3. Guide Question
    Last Post: 05-19-2016, 12:39 PM
  4. Server 4 guide issues on Avov (missing all uk channel guide info)
    By SebsiBC in forum IPTV Private Server (NFPS)
    Last Post: 04-10-2016, 04:21 PM
  5. Ivue TV Guide channel question
    By kizer8 in forum Kodi Discussion
    Last Post: 07-26-2015, 09:36 PM
