Results 1 to 4 of 4
Thread: Need help
    Nov 2015
    yes I do
    Need help
    Just purchased a donation code to renew an expired iptv service. But Im having problem connecting it to the IPTV server. "Your account is blocked or expired." Im not currently using any VPN nor firewalls on my local network. MAC address is the same as before.
    Ive tried IPTV reset, power cycle, and used both portals below, but no luck.
    IPTV PORTAL: p1.iptvrocket.ru
    FULL IPTV PORTAL URL: http://p1.iptvrocket.ru/c/index.html
    Quote Originally Posted by nib01 View Post
    at the service website, log onto your code and delete the MAC associated with this code.
    Then log back on and re-attach the MAC and then log back on at website again and do an IPTV Reset.
    check results.
    If using a dreamlink or buzz or other similar box, try this with no credentials added in the box's server setup.
    (credentials = username/password)
    Leave the 'credentials box' unchecked and do not add them.
    - Frank Zappa
    Nov 2015
    yes I do
    My dreamlink T1 has the following info on Portals menu. Does not have the exact info as mentioned above "server setup". I tried the method above but still didnt work.
    Portal Nickname
    Portal URL
    Login Required >>Unchecked
    User ID (No User ID)
    User Password (No Password)
    Mar 2019
    Portal Nickname
    Portal URL
    Steps required to assign a MAC# to a NEW Donation code, from an "Expired" Donation account that was using the same MAC#;
    *Make sure your STB is Off, not on Standby (best is to unplug).
    Log in to the OLD account and remove the MAC# by clicking "Change IPTV MAC" and leave blank (same as entering all "00"'s (00:00:00:00:00:00))
    Save the change, then do an IPTV Reset.
    Wait 5 minutes
    Log in to the New account and link the STB's MAC# to the account by entering the MAC# and save by clicking Apply.
    Wait a few more minutes then Power on your STB.
    *If the Server URL is the same as the old account, you should not have to change the URL in your STB settings, otherwise that would have to be changed, saved, then cycle the STB power off/on.
    /Shooty
