Results 11 to 20 of 24
Thread: Kodi 18.8
    tester
    Yes I do
    Get real debrid that should solve your problem
    Mar 2019
    Quote Originally Posted by djmcshain View Post
    I think the problem is with the new KODI 18.8
    never had this problem with the 18.6
    How do I delete 18.8 and download 18.6
    Host scraping sites continuously going down, then up w/new urls etc.
    check this;
    How to Install New Exodus Version Advanced Info
    Latest Kodi Exodus Info (OCT 2020)
        Repo Name: Kodi Bae Repo within Lazy Repo
        Source URL: https://lazykodi.com
        GitHub Username: kodibae
    2020 Kodi Exodus Update Quick Step Guide
        Click Kodi System icon kodi settings menu item icon > File Manager > Add Source > <None>.
        Type http://lazykodi.com, click OK, name it lazy, then click OK again.
        Return to the System utility and setting tiles area and click Install from zip file.
        Go into lazy > -= ZIPS =- (NOT -= REPOSITORIES =-) and click on KODIBAE.zip for repo install.
        From the Add-ons browser, click “Install from repository” > Kodi Bae Repository > Video add-ons.
        Scroll down to and click on Exodus, then click the Install button for Kodi Exodus download and installing to begin.
    Here is a link to kodibae repo zip file;
    https://github.com/kodibae/repository.kodibae/blob/master/repository.kodibae/repository.kodibae-3.0.0.zip
    /Shooty
    Electromagnetic Wrangler Extraordinaire
    Jan 2015
    I uninstalled KODI 18.8 wiped clean to start over.
    I installed KODI 18.6 so far so good.
    I put in your kodi Exodus and I get a message unable to connect??? what is this???
    I put in covenant 1.1.34
    I put in Exodus Redux and on both of these add-ons when
    I go to watch a movie I get the no stream available last week
    these worked fine-what the hell changed????????
    something here
    JOKER Tha Joker's Avatar
    Sep 2016
    Do what post 11 says.
    Bullwhale
    djmcshain heres what i would do if you are not going to get a real-debrid account.Install either 18.8 or 18.6 and then install a dev build were you have a few different addons and try all of them to see if any work to make sure its not your internet that is the problem.then if they are working and you only want a couple of addons then find a couple of good ones.and real-debrid and a vpn would be the way to go.
    Jan 2015
    If I go with the Real Debird will that solve my problem with
    the movies on my add-onsI I am on fixed income and cant 't
    afford both VPN & Real Debird after paying for my Rocket.
    something here
    Bullwhale
    nothing is a for sure thing.
    1 have you rebooted your router you should
    2 have you try to install any ones whole build and try the addons in that build (google best kodi builds)
    and see if any of thier addon work if any of them do then delete the build and google just them addons and install them only
    if you do not want to keep the whole build.
    3 if none of the addons work that are in the build you install and you are on wifi then try hard wired
    (this is trouble shooting also what i mean by some ones build is that it has all the addons installed all ready
    Curious, You said You Loaded Kodi 18.8... Did You Check the "Unknown Sources" to bee Allowed...?!?
    Bullwhale
    he said he tried 18.8 and 18.6 and installed Exodus Redux and a different add-on and both gave same thing no links.(Unknown Sources should all ready be enabled if he installed some add-ons)now that being said if he tried 2 different V of kodi like 18.8 and 18.6 and both are doing the same thing i don't think kodi is the problem that why i said to try what's in post 17
  1. Replies: 1
    Last Post: 02-14-2017, 06:16 PM
  2. Replies: 1
    Last Post: 04-26-2016, 06:51 PM
  3. Replies: 0
    Last Post: 03-06-2016, 10:52 AM
  4. KODI MAKERS MAD AT IPTV, piracy, WHAT GOOD IS KODI THEN IF CANT USE FOR MEDIA
    By fleisch80 in forum IPTV Private Server (IPTV66)
    Last Post: 02-18-2016, 01:59 AM
  5. Mucky Duck AFDAH Kodi, GenVideos Kodi, Movie32HD Kodi Add-ons
    By Kimbo in forum Addons & Repositories
    Last Post: 02-05-2016, 03:45 PM
