Results 1 to 10 of 12
    Oct 2015
    no channels working, rocket checker not working, ??????
    site mail not working, how would i go about getting any help?
    JOKER Tha Joker's Avatar
    Sep 2016
    Channels are working, rocket checker is working. Send a pm to crazed for help.
    I sent ferrous a message offering any assistance, but have not received an answer yet, and now I am just leaving the building for a few hours, maybe 6 or 7 hours.
    I will be back
    Jan 2015
    Sarasota, Fl.
    No American channels are working.
    TV Addicted valdovic's Avatar
    Jan 2015
    All channels are freezing...
    Jan 2016
    Mine will not load or freezes so bad you cant watch it but a friend has the same setup I do theirs plays fine. Has to be a conflict with my ISP because I can stream with other apps with out a problem. This happened several years ago with people who have the same ISP I do and something was done to fix the conflict. Mine has been doing this for about three weeks now.
    Oct 2015
    Big thanks to Crazed, helped me out and now I have things sorted out as best as possible, my issue was a vpn problem and a search engine interferance.
    Hopefully things work out from here. Thanks Again Crazed 8.4
    I have two setups a mag 254 and firestick and the freezing and buffering started 3 weeks ago. Both are lifetime donations on ethernet connections. I have done nothing to my settings in years and keep hoping the situation is being addressed. IS there something I should do? Or has my internet provider, Verizon figured a way to mess with me? Please help! Thanks!
    I should say that I am USA based, attempting to view USA channels. Also the expanded channel list for local stations is exciting and seems to be 'in the works' as they 'work' intermittently, can I also assume that these will be up and running in the near future?
    I also do not use a VPN as my understanding is that it would negate my donations. Must also admit that I am not well versed in setting these units up, and like I said I haven't played with any settings in many years and not even sure if I would feel comfortable in doing so. I have pulled power from both and let them reboot to see if it helps but to no avail.
  1. Channel not working on Rocket. Wanted to check if working on NFPS ...
    By devnull1970 in forum IPTV Private Server (NFPS)
    Last Post: 12-13-2017, 11:25 PM
  2. IPTV Reset & Rocket Checker - Not Working
    By ptk61 in forum IPTV Private Server (Rocket)
    Last Post: 02-06-2017, 03:42 PM
  3. Route checker not working again
    By monty49 in forum IPTV Private Server (IPTV66)
    Last Post: 12-29-2016, 01:00 AM
  4. box blocked , donation checker mot working
    By jumbo66 in forum IPTV Private Server (Rocket)
    Last Post: 07-04-2016, 08:46 PM
  5. STB Emu VOD and adult working but live channels not working
    By kastaway in forum IPTV STB Emulators
    Last Post: 02-07-2016, 06:14 PM
