I have been gone for a while ...again.
Now I can't log in. My server setting had disappeared and so I reentered them but am not able to connect. i just get the spinning wheel for aver an hour.
What next, are we down?
thanks
thanks
what box are you using? try to perform a reset on iptv provider site.
try to change portal and see if that helps.
It says Mac already in use? You do have the Mac attached to the donation?
You do. Never mind, I thought you meant it said 'Mac already in use', which is a different error. If the Mac is attached, then change portals like Ryu suggested.
