Results 1 to 10 of 11
    Chief Ninja
    Recording... thumb drive vs hard drive that is the question!!!
    Which is better or has the better performance a thumb / flash drive are a external hard drive.. Assuming both have the same usb 2.0 speed.
    Thanks,
    in my opinion If external hard drive is not a ssd then I would use thumb/flash drive but disadvantage is that you may not have too much capacity.
    yea i only use ssd drive now there so cheap and f--king fast
    Chief Ninja
    Thanks so much
    Chief Ninja
    Thanks, what size ssd do I need? They are expensive compared to the old spinning style HDD.
    Do you have a good place to get other than the big box stores?
    Thank you
    Quote Originally Posted by guest View Post
    Thank you
    really depends on how much you want to record. im not sure if bwcbob has them but try to pm him and he may have and can give you good deal. or try ebay or amazon or newegg
    Chief Ninja
    Thanks, I guess I'll buy as big as I can afford
    Mercenary floder2's Avatar
    yea
    What internal SSD drive can the 4500 use ?...or is there no slot for internal.... 2.5 inch SSD ..... mSATA SSD ..... or M.2 SSD
    Chief Ninja
    Quote Originally Posted by floder2 View Post
    You need USB, but you can get a HDD cradle that is UBS that will accept 2.5 and 3.5 HHD in the same slot. Of course one at a time.
    yea
    Thought maybe there was an internal ssd slot..Would be very fast....instead of the external USB....
  1. SATA hard drive
    By crazed 9.6 in forum BuzzTV XRS4900
    Last Post: 09-23-2021, 10:26 AM
  2. Free 1TB hard drive
    By Ryu in forum BuzzTV XRS4900
    Last Post: 07-07-2021, 11:08 PM
  3. Formuler Thumb Drive Accessible From Network
    By billyjbob in forum Formuler Z8 & Z8 Pro & Z10
    Last Post: 02-03-2021, 03:06 PM
  4. recording to external hard drive
    By densan in forum Dreamlink T6
    Last Post: 09-06-2018, 04:38 PM
  5. Recording VOD Movies on a USB Hard Drive
    By MoneyTK in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 02-25-2015, 11:50 AM
