Results 1 to 5 of 5
    Apr 2020
    XR4000 and Android for Work
    We're testing out a BuzzTV XR4000 for deployment in digital signage. But we're hitting a problem where we can't enroll the devices with Android for Work.
    On a typical Android device, you do a factory reset, Android asks to setup WiFi, then asks for a Google Account. There, you enter afw#whatever_company_name, and it moves into the enrollment process. But the Android build used in the BuzzTV XR4000 skips these steps.
    From our Mobile Device Management dashboard:
    "On a new/factory reset device(running Android 6.0 or later versions), specify afw#memdm as the default Google account during initial device setup to install the ME MDM app on the device automatically."
    Does anyone know how to enroll a BuzzTV device with Android for Work? Do we need to install specific firmware or something?
    Warrior
    So you cant go into apps and sign into google there?
    Apr 2020
    I can sign into Google after the fact, but the "afw#memdm" account only works during the initial device setup - which BuzzTV's version of Android skips past.
    Warrior
    Quote Originally Posted by TonyDowne View Post
    I can run this by the buzz guys but its likely something that has to be done from the mobile device management side
    i dont know of any iptv box that makes you sign into google first but ive only owned 10 or so different ones
    Mercenary floder2's Avatar
    yea
    Never been asked for afw#whatever_company_name Google Account with any iptv box I have ever used ......always had to open google after all setup has been done from a reset
  1. Does the STB Emulator work on Android? (using iptvRocket)
    By stevensgl in forum IPTV STB Emulators
    Last Post: 07-29-2016, 10:26 PM
  2. Does Showbox only work on Android systems?
    By 82harley in forum Addons & Repositories
    Last Post: 05-03-2016, 02:06 PM
  3. Will MXV android tv box work for IKSROCKET
    By bigshadow in forum Chit Chat Lounge
    Last Post: 08-21-2015, 12:03 AM
  4. Android box epg url don't work.
    By bobd120 in forum IPTV Private Server (NFPS)
    Last Post: 08-08-2015, 04:22 PM
  5. Service work with android box or kodi?
    By abrasope in forum Chit Chat Lounge
    Last Post: 07-19-2015, 07:33 PM
Tags for this Thread
