Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: VOD. Lock
    Mercenary floder2's Avatar
    yea
    I was able to check out a buzztv 3000 today and yes you can lock adult categories in VOD...but the 4000 won't
    Warrior
    Quote Originally Posted by floder2 View Post
    I have brought this up with the devs Ill advise what they say.
    JOKER Tha Joker's Avatar
    Sep 2016
    I am able to lock the adult categories with a 4000XRS? Red button to view categories, red again to organize, and then hit ok on for adults which changes them from visible to invisible and now are no longer viewable in the "all" vod option unless you go back into organize category and turn it back on.
    Sep 2016
    This is in VOD categories. It will allow me to lock the adult category. Once locked is no longer visible in the all option of VOD. If you go back into organize, you need the password to turn it back on to make visible once again in the 'all vod category'.
    Warrior
    Quote Originally Posted by Tha Joker View Post
    thanks joker
    yea
    4000XR wont change from visible to invisible for adults...other catagories can change though....
    While in VOD and using the red button it brings up the menu to turn categories invisible or visible.
    I can make the Adults invisible and it works correctly with the Adult VODs have disappeared from the category listings and from the movie selections as well.
    Seems to work correctly here too floder
    - Frank Zappa
    I just noticed that if you have the Adult category open in the background, then the function to change to invisible does not work.
    The category has to be exited first. and set to ALL category or probably any category except the one you want to set to invisible.
    - Frank Zappa
    yea
    Ok I'll keep messing with it..........thanks.......
    yea
    GOT IT................ go to VOD push red category button ....and push Category Red button again .... go down to adults on the list "turn off" exit ...Now Vod hides the Adults ...go back to category again ...turn on Adults ..input password (0000) ...Exit....now adults are viewable ................
    thank You All....................
  1. country lock and VPN
    By mootz in forum IPTV Private Server (Rocket)
    Last Post: 10-22-2021, 11:16 PM
  2. country lock
    By raza30 in forum IPTV Private Server (IPTV66)
    Last Post: 07-14-2019, 01:00 AM
  3. Lock / Unlock
    By slimshady in forum BuzzTV 3000 series models
    Last Post: 01-12-2019, 08:58 PM
  4. Box is lock by Server
    By ldo15 in forum AVOV IPTV Boxes
    Last Post: 06-25-2016, 01:30 PM
  5. Lock
    By GCOOP in forum aVOV TvOnline+
    Last Post: 05-20-2016, 08:42 AM
