Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
  1. #21
    (openbox/eyebox/alphabox) RalinkRT5370 USB 2.0 /1.1 Type A IEEE 802.11 b/g/n 150Mbps is identical to the Infomir and works exactly the same
  2. #22
    Jan 2015
    Trinidad and Tobago
    i used a generic next nano USB wireless and it works perfectly on my mag254
  3. #23
    Need some advice guys I need a good adapter with good distance. I live in a 2 story house what do you guys recommend???
  4. #24
    Junoir Member redhawk's Avatar
    Realtek 8192CU wireless LAN 802.11N USB2.0 Netwok Adapter
    Tried to use the Realtek adapter, works great in my laptop but does not seem to receive in my mag 254, anyone tried this adapter?
    redhawk
  5. #25
    Quote Originally Posted by remmirt View Post
    I too just purchased the dlink dwa 160. When I plug it into the usb port on the Mag 254 it doesn't recognize it. Any help from folcan99 or anyone else would be greatly appreciated. Thanks in advance.
    I am also having problem with getting the adapter recognized..did not see a response ..any help out there ? thanks
  6. #26
    Quote Originally Posted by folcan99 View Post
    I personally am using a Dlink DWA 160 for over a year and works great. It has both 2.4 and 5.0 GHZ. Why is it better? Most Electronics in the house use 2.4 GHZ which may cause interference with the reception of the router so its better to run on 5.0 where it would be clear of any disconnects or interferences. Your router must support both 2.4 and 5.0 GHZ.
    Great little unit thanks. Set it up right on the box.
  7. #27
    it should see it Wireless Security: 64/128 bits WEP WPA/WPA2, WPA-PSK/WPA2-PSK (TKIP/AES)
  8. #28
    Banned
    Full list of WIFI adapters STB MAG-200/245/250/254/255/270/275 according to infomir.
    http://wiki.infomir.eu/doku.php/stb_webkit:faq:wi-fi
  9. #29
    Hi,
    I have an Edimax 7711uan but the mag doesn't recognise it.I plugged the adapter in a computer first,everything is working bit when I connect it to the mag 254 it says wifi adaptor not connected.Does someone know the solution?
  10. #30
    wish I would have read this sticky before buying my wireless adapter.this trendnet is not recog nized by my 254.
  1. Wifi device not found(w3 wifi dongle)
    By BobbyBaca in forum Dreamlink T2 Prime
    Last Post: 06-16-2020, 07:57 PM
  2. Changing WiFi Information/Disabling WiFi on 254
    By xgxg889 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 12-19-2016, 04:32 AM
  3. App options
    By sperminatorx in forum aVOV TVOnline
    Last Post: 10-26-2015, 05:10 PM
  4. specs/options
    By tdcarnut in forum Chit Chat Lounge
    Last Post: 08-01-2015, 07:02 AM
  5. Sat Options
    By grafix_d in forum Chit Chat Lounge
    Last Post: 06-12-2015, 12:07 AM
