Results 1 to 8 of 8
Thread: T1 Freezing Up
    Aug 2016
    Question T1 Freezing Up
    After one of the 2 past updates my T1 randomly freezes up and I get red and purple bars come on screen and stays frozen I tryed unplugging everything and left like that for 2 days and still the same... I factory reset like 3 times and still the same...anyone else have this happen and is there a way to try and fix this
    Aug 2016
    Is there a master reset pinhole on this box where you can reset it by poking it with a needle cause I cant find it
    sounds like hardware issues..it getting hot ?
    they get old.
    Messes things up.
    I once heard from a tech that any device is made to last less then 3 years and after that is a free for all.
    Even the most tech units will not last years upon years, according to stats.
    The knock offs last considerably shorter.. They built with inferior parts.
    - Frank Zappa
    If you get it working...
    get that T1 up on stilts.
    Put some distance under it.
    Let the air flow get under it. That is where it is vented, on the underside.
    Don't put an android device in a freezer type atmosphere thou, them androids will not function correctly with out the heat
    - Frank Zappa
    Aug 2016
    Thanks Crazed 8.4 that's what I kinda figured that it's all it gave🥺..I guess on to the next one which dreamlink model would you recommend to get next cause Iam way behind on models🤣
    Quote Originally Posted by Imp08ala View Post
    Dreamlink T3
    That model is fairly new, so you;d have 3 or 4 good years outta it
    - Frank Zappa
    HD stands for Harley Davidson 4wheelin's Avatar
    i have the T1 in spare room and it has been working good ,i have not used it in 2-3 days but has been good up until then.
    Nov 2015
    yes I do
    Same problem here. Freeze up randomly. NFPS is way better than rocket imo.
  1. Freezing freezing and onlt freezing
    By Bguanajua in forum IPTV Private Server (IPTV66)
    Last Post: 03-29-2020, 02:46 AM
  2. Is your box freezing? or how to make this freezing better?
    By hotwarmguy in forum IPTV Private Server (Rocket)
    Last Post: 01-31-2017, 03:21 AM
  3. freezing freezing all chanels freezing
    By FLOTADITO in forum IPTV Private Server (Rocket)
    Last Post: 07-02-2016, 03:27 PM
