Results 1 to 3 of 3
    dreamlink /formuler activation problem
    I am a reseller. yesterday I activated a donation inserting the mac address that is on the box. activation went thru however the box did not connect. I went into the rocket server and noticed that the mac address had been altered and was different from the id: field which has always been the same as the mac field. the id field shows 00 1a 79 xx xx xx the mac field now shows 00 1e b8 xx xx xx which is not a valid mac. I have 5 active boxes both dreamlink and formuler z7 & z8 all show the change
    when I went back to my iptv resellers panel to change the mac to 00 1e b8 , I got an error code. I think the system has been compromised. has any one else had this experience? can an administrator direct me in the right direction. is there an update coming?
    mike
    Jun 2016
    Use the ID that starts with 00:1A:79: always
    try this. next time when you activate your new service don't add Mac address. just activate without Mac address. once done then go to your active donations click on new code the one you just activated and enter Mac and you should be good to go. let us know please. thanks
  1. Dreamlink T3 & Formuler Z8
    By tuan170 in forum Dreamlink T3
    Last Post: 09-27-2019, 01:14 PM
  2. Formuler vz dreamlink t1 plus
    By supaman32052 in forum Formuler Z7 & Z7+
    Last Post: 05-22-2018, 10:45 PM
  3. Dreamlink T2 vs FORMULER z7+
    By Hostile in forum Dreamlink T2
    Last Post: 12-30-2017, 04:34 AM
  4. New Formuler/Dreamlink
    By divo77 in forum Dreamlink T1 Plus
    Last Post: 11-30-2017, 06:39 PM
  5. problem with activation
    By henriquez in forum Chit Chat Lounge
    Last Post: 03-15-2017, 08:52 PM
