Results 1 to 10 of 13
Thread: Mag 420
    Mag 420
    Just bought 4 new mag 420 w1. Loaded first one. Says stb not supported. Updated software still the same
    Is there a trick or do I have to go down to the 320 w1
    Jan 2015
    Did you ever figure this out. Did you have to go down to 320?
    I bought one as well and got the same stb not supported. js-no news on how to make it run----they said they did special maintenance and to reset mac but this did not work. js
    I believe the issue may be that the 420 and along with other infomir models now run with the Ministra TV platform (Middleware supported).
    They switched from Stalker Middleware to the Ministra and not all server support Ministra
    Mar 2019
    MAG250, 254, 256 and some other MAG models running Stalker middleware (Ministra middleware is not currently supported)
    http://iptvtalk.net/showthread.php?3...381#post201381
    JOKER Tha Joker's Avatar
    Sep 2016
    I figured out a really good trick to fix! Buy another STB that you know is supported!
    I bought service from a provider for my roku and had to download the ministra platform in order for it to work. My guess is that some providers use ministra and would function with 420 mags?
    Mar 2019
    Quote Originally Posted by sugarmtn View Post
    You are correct.
    There is a Ministra Player for the following Platforms;
    Ministra Player AndroidMinistra Player for Andrоid TV and STB
    Ministra Plаyer AppleTV
    Ministra Player iOS
    Ministra Player on Roku
    Ministra Player Tizen
    Ministra Player WebOS
    Ministra Player Smart TV
    Ministra Web Player
    * There is a Patch that the Provider may be able to implement, so that Ministra STB's can login to Stalker Portals;
    • How to run MAG420/MAG322/MAG324 on the portal version 4.9.x?
    *Patch To log in to the Stalker Middleware portal version 4.9.x
    https://wiki.infomir.eu/eng/ministra-tv-platform/ministra-installation-guide/faq/how-to-run-mag420-mag322-mag324-on-the-portal-version-4-9-x
    /Shooty
    I wonder if a 420 would run as well with the patch for stalker as it does on ministra?
    Mar 2019
    The patch is installed on the providers backend Stalker system, not the MAG STB's.
    *It's probably a moot point anyways, as I do not think they would implement it.
