Results 11 to 20 of 34
    have you started the BuzzTV app (LiveTV) ?
    That may need to be started so it can do a reboot to complete the update process.
    Apr 2016
    Canada
    when I go to Menu, at the bottom says
    Version 2.0 (247)
    is that right?
    Banned
    Nov 2017
    in front of pc
    Quote Originally Posted by montell View Post
    Version 2.0 (247)
    is that right?
    you will be at 317 after update
    Apr 2016
    Canada
    it says downloading 49 Mb of updates and then it says "installing updates " but it never installs it? cause my version after update says 247 and not 317?!
    Banned
    Nov 2017
    in front of pc
    and you did a factory reset?
    Apr 2016
    Canada
    Hi du,
    But if I do factory reset, wouldn't I lose all my infos?!
    thanks
    Banned
    Nov 2017
    in front of pc
    Hi du,
    thanks
    write down server info
    Apr 2016
    Canada
    how about the apps and all that? wouldn't they also be gone?!
    Banned
    Nov 2017
    in front of pc
    sorry I meant uninstall updates or you could also try clear data
    Apr 2016
    Canada
    Thanks du, but where do I go to uninstall updates and clear data? just want to make sure I am not clearing all my data by mistake
  1. New Public Release for Buzz 3000 + Basic + 3900
    By NBS in forum BuzzTV 3000 series models
    Last Post: 11-16-2019, 11:07 PM
  2. Official Public Release for XPL 3000 + Basic + 3900 + 3100
    Last Post: 10-29-2019, 11:04 PM
  3. Official Public Release for XPL 3000 + Basic + 3900 + 3100
    Last Post: 10-28-2019, 07:45 PM
  4. Official Public Release for XPL 3000 + Basic + 3900 + 3100
    Last Post: 10-28-2019, 07:43 PM
  5. Replies: 0
    Last Post: 12-17-2018, 08:41 PM
