Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Jun 2019
    good afternoon friend thanks for helping me, so try to install following all the steps as you say in post 33 and had the file in my usb and when to put ok in bootstrape usb me file / mag250 / imageupdate not present try it with another USB and I got the same and to give you my donation number I can not find where to send you private message
    Jun 2019
    I have 2 active accounts in 2 mag250 different one in the room another in my room and only the one in my room is the one that serves 100 the other is the problem
    does that mag250 have more then one USB slot ?
    If so, then try the other one.
    Click on my name and select 'Private Message'
