Results 1 to 7 of 7
    May 2019
    Unhappy Need help with buzz tv xlp 3900
    I NEED SOMEONE AT BuzzTv directly who in return can provided an firmware update that i am able to put in USB thumb drive and update my system with the most recent Buzztv firmware. my box updated recently and its showing me mygica..is it possible to go back to my old buzz tv android firmware ?
    Banned
    Nov 2017
    in front of pc
    Quote Originally Posted by Lopez758 View Post
    I NEED SOMEONE AT BuzzTv directly who in return can provided an firmware update that i am able to put in USB thumb drive and update my system with the most recent Buzztv firmware. my box updated recently and its showing me mygica..is it possible to go back my my old buzz tv android firmware ?
    you need to send it back
    May 2019
    why do i have to send it back ?
    Banned
    Nov 2017
    in front of pc
    because they're not going to send you the firmware that makes it a buzz
    Jan 2019
    Strange this shouldn't be even possible.... have you changed the MAC address on your buzz ?
    May 2019
    yep very strange ! but i got it fixed now ! i just bought it back and they reinstall the firmware. so all is good now
    Mar 2019
    It is made by the same manufacturer "Geniatech"
    It is one of the only boxes you can install the buzz tv apk.
Tags for this Thread
