Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 67
Thread: Freezing
    what box you are using?
    Feb 2018
    Ok, i have changed DNS to icloud ones and still the same, I have the problems on different locations, office, home, sisters house, I have checked 6 different places, differen t ISP and is the same issue.
    freeze every 5 seconds and VOD seems to load but freezes on the irst 2 seconds. The night i detected freezengs i swa VOD, the next day got the problem.
    Feb 2018
    Im using android box MXQ with STBEmu pro, long time worcked perfect,now is impossible to watch anything
    Feb 2018
    Tried also connecting to my cell as a hotspot and the same.
    Ambassador
    Aug 2018
    Quote Originally Posted by cometin View Post
    Sounds like you have isp issues from what i can see there is no one else complaining about constant freezing. Do have another router you can hook up to by pass your provider one?
    to me sounds like a stbemu or box its self. if you can get m3u playlist and try with vlc or perfect player on your box and see the result. if gets better then its the app but if still the same then its the box.
    Feb 2018
    Ill check that, i have checked with at least 4 boxes on different locations, MXQ, X96, Ill check the VLC and on my pc and get back to inform results
    yes please, will wait for your response.
    Ambassador
    Aug 2018
    As for using a hot spot from a cell phone.I'm not sure how good that works.I know not good with mine since Hd switch over.Have you tried it?
    Quote Originally Posted by Dodgeit1 View Post
    I never tried with hotpot. never needed but will try over the weekend and if I don't forget will post the result.
  1. Freezing freezing and onlt freezing
    By Bguanajua in forum IPTV Private Server (IPTV66)
    Last Post: 03-29-2020, 02:46 AM
  2. Is your box freezing? or how to make this freezing better?
    By hotwarmguy in forum IPTV Private Server (Rocket)
    Last Post: 01-31-2017, 03:21 AM
  3. freezing freezing all chanels freezing
    By FLOTADITO in forum IPTV Private Server (Rocket)
    Last Post: 07-02-2016, 03:27 PM
