Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
  1. #21
    Adding the carousel lengthens the track from 1.99 miles to 2.52 miles and will make the technical road course even more tight. As a result, Goodyear is bringing one of its most tractive tread compounds in the entire 2019 tire lineup.
    Goodyear will also bring its wet weather radials for Sonoma should NASCAR decide that conditions warrant. But they tell us it never rains in Northern California.
  2. #22
    cool
    I race this course on my xbox Forza Motor-Sports games.
    The game has both versions of them corners (actually 3 versions in all).
    Them corners can be tricky,especially between 4 and 5
    seems when you get around corner 4 and then almost around corner 5 and with the track still heading to the right, well if you are not careful you end up in the grass on the left. And to top it off, there is a bit of a crest there in the track, so as you leave corner 5 (or so you think you are leaving it), you can not see the upcoming soft right, after you crest the hill there is still more corner !! ... it can make for a real mess if not on the ball.
    "NASCAR updated its rule book Wednesday to include language in the book’s penalty section that series officials could consider any damage caused during a race when assessing if a violation has occurred.
    Section 12.4.a now reads (bold added to highlight updated section):
    “NASCAR may issue penalties as it deems fit to provide for the orderly conduct of the sport. Such determinations may be made by NASCAR before, during, or after the Event, and may consider, to the extent deemed reasonable by NASCAR in the interests of racing competition and fairness, any modifications caused or required as a result of damage caused by In-Race accidents.
    The change could impact whether a winner (or any other car inspected after the race) is disqualified for failing post-race inspection.
    Section 8.3.c of the Cup Rule Book already had a similar statement in regards to vehicle eligibility. It stated:
    “Such determinations may be made by NASCAR before, during, or after the Event, and may consider, to the extent deemed reasonable by NASCAR in the interests of racing competition and fairness, any modifications caused or required as a result of damaged caused by In-Race accidents.”
    Rear spoiler with the wicker that was added at Talladega. Photo: Dustin Long
    NASCAR also announced Wednesday that the Cup package for next weekend’s race at Daytona International Speedway will be the same as used in the race at Talladega Superspeedway.
    At Talladega, teams had a wicker added to lower speeds. What will be used at Daytona will be a one piece spoiler/wicker. The overall dimensions remain the same for the spoiler.
    Tags: Daytona International Speedway, nascar, Talladega Superspeedway"...!
  4. #24
    Lightbulb
    Tidbit on Tires :
    All three of NASCAR’s national series will be in action this weekend at Chicagoland Speedway, and they will all compete on updated tire combinations on the 1.5-mile track.
    Compared to what was run at Chicago last year, both left and right-side tires feature construction updates to align with what is run at other speedways, while the right-side tire has also gone from a multi-zone tread tire to a single zone tread tire and will increase grip.
    This tire combo was confirmed at a Goodyear test at Chicagoland on May 7. The drivers who participated in the test were Brad Keselowski, Ryan Newman and Paul Menard. As on all NASCAR ovals greater than 1 mile in length, teams are required to run inner liners in all four tire positions at Chicagoland. Air pressure in those inner liners should be 12-25 psi greater than that of the outer tire.
    “Based on some indications we saw at our test at Chicagoland, we felt like we could bring some additional grip that will help the cars in traffic,” said Greg Stucker, Goodyear’s director of racing, in a press release. “When a trailing car closes in on a car ahead, it loses some aerodynamic downforce, so the additional mechanical grip from a more tractive right-side tire can help offset that loss. The 2019 Cup rules package has produced some good side-by-side racing so far, but based on what we saw at our test, as well as additional driver feedback, we feel like a more tractive right-side compound might help the cars throughout the field.”
    "Here is the tire info for the weekend.
    Set limits: Cup: Three sets for practice, one set for qualifying and nine sets for the race (eight race sets plus one set transferred from qualifying or practice)
    Xfinity: Eight sets for the event
    Truck: Seven sets for the event
    Tire Codes: Left-side — D-4928; Right-side — D-4930
    Tire Circumference: Left-side — 2,227 mm (87.68 in.); Right-side — 2,248 mm (88.50 in.)
    Minimum Recommended Inflation: Left Front – 19 psi; Left Rear – 19 psi; Right Front – 48 psi; Right Rear – 44 psi"...!
  5. #25
    Good stuff. I had no idea that they added that wicker for Talladega. I'm ok for making things stickier with added speed, as cars aren't meant to be flying projectiles, but once they are airborne, its heartstopping.
  6. #26
    July 2, 2019 at 3:05 PM
    NASCAR has switched things up for this weekend’s Monster Energy NASCAR Cup Series race at Daytona International Speedway.
    Stage lengths are going to be longer Saturday night for the Coke Zero Sugar 400 (7:30 p.m. ET, NBC, MRN, SiriusXM NASCAR Radio). Stages 1 and 2 are both set to increase by 10 laps, with Stage 1 now ending on Lap 50 and Stage 2 now ending on Lap 100. As a result, the final stage will technically become shorter, coming in at just 60 laps rather than 80 since the checkered flag will still wave on Lap 160 — if all goes according to plan.
  7. #27
    NASCAR wanted to take out fuel mileage a factor in the stages, forcing teams to make a pit stop sometime during the stage.
  8. #28
    RULES PACKAGE
    Teams will use the 2019 rules package with new tweaks specifically tailored for superspeedway racing at Daytona — the first time used at the track following restrictor plate usage at the Daytona 500. The package includes a 0.922-inch tapered spacer (replacing the restrictor plate), 9-inch rear spoiler, 1-inch bolt-on track bar mount, a tapered radiator pan, two-inch splitter overhang and aero ducts. Just as at Talladega in April, teams will use a 1-inch wicker extension placed on top of the 9-inch spoiler.
    Cup Series teams also will participate with a new left-side tire compound for the Goodyear Eagle superspeedway radial, a construction update that makes its debut this weekend. The update was recommended after a two-day test at Daytona in February. Teams will be provided with two sets of tires for practice, one set for qualifying and seven sets for Saturday’s race — six race sets plus one set transferred from qualifying or practice.
    “The goal was to incorporate the basic elements of the 2019 rules package into the aerodynamic configuration for the superspeedways of Daytona and Talladega, so they are no longer unique in that perspective,” said Greg Stucker, Goodyear’s director of racing. “With that alignment established early in the test, we took the same approach to the tires. The result was a tire combination with the same constructions we run at the intermediate tracks, married with the tread compounds run at Daytona in February.”
  9. #29
    Kentucky RULES PACKAGE
    The Kentucky Speedway rules package will mirror the setup used at other 1.5-mile tracks this season — the same package most recently at Chicagoland in the race won by Alex Bowman. The engine will be fitted with a tapered spacer generating an expected horsepower of about 550. Cars will also feature aero ducts.
    TIRES
    Each Monster Energy NASCAR Cup Series team will get 12 sets of Goodyear Eagle Speedway Radials — three sets for practice, one set for qualifying, and eight sets for the race (7 sets plus one transferred from qualifying or practice). The tire features a new compound change that adjusts for a relatively newer and smoother racing surface, as Kentucky was repaved before the 2017 race.
  10. #30
    RULES PACKAGE
    The New Hampshire Motor Speedway rules package will mimic the setup used at other 1-mile tracks this season — the same package most recently run at Sonoma Raceway in the race won by Martin Truex Jr. The engine will be fitted with a tapered spacer generating an expected horsepower of about 750 and there will be no aero ducts on the cars.
    TIRES
    The Monster Energy NASCAR Cup Series teams will get 13 sets of Goodyear Eagle Speedway Radials – three sets for practice, one set for qualifying and nine sets for the race (eight race sets plus one set transferred from qualifying or practice). Both compounds run at New Hampshire are the highest performing in its tire lineup. Teams are running two new tire codes compared to what was run last year, featuring construction updates. This is the only track in which teams will run this specific tire code and like other ovals 1-mile or less in length, teams will not run inner liners in their tires.
  1. The dorm rules....
    Last Post: 08-14-2019, 04:23 PM
  2. Forum Rules
    By ilan in forum IPTV Talk News & Announcements
    Last Post: 04-24-2018, 11:54 AM
  3. The House Rules ......
    Last Post: 04-13-2018, 12:42 AM
