Results 1 to 10 of 18
Thread: Help Please !
    Apr 2016
    Canada
    Exclamation Help Please !
    Hello everyone,
    How can I change Player on my Buzz tv XPL 3000 please?
    I keep getting Error code trying to play tv series episodes?!
    while the BuzzTV app is open and working, use the menu button to bring up a side-bar menu onscreen.
    Scroll down to Configuration, open that and you can switch between the default and the other Player
    Apr 2016
    Canada
    Thank you sir
    Apr 2016
    Canada
    btw, which Player do u recommend please?
    thanks
    Banned
    Nov 2017
    in front of pc
    Quote Originally Posted by montell View Post
    thanks
    when I have issues I use secondary
    but you can't record
    Apr 2016
    Canada
    Oh thanks DU, is Secondary the name of the player?
    Apr 2016
    Canada
    thanks DU ,I arrived at the answer
    Banned
    Nov 2017
    in front of pc
    you're welcome
    Apr 2016
    Canada
    It seems as if the "Default" to be the best choice though, although choosing "secondary" started playing the video but kind of slow.
    I also tried "internal" and "old" which did not appear to be very efficient.
    Banned
    Nov 2017
    in front of pc
    what version of app are you using?
