Page 16 of 30 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 298
  1. #151
    Your Clue #3, if a Car was Newly Introduced in an Auto Show in 1969, can it be designated as a 1969(Manufacture Date) or 1970(Model Year)...?!?
    OK, so 1970 is not Allowed...? I ask this because I see 1970 being used...! Don't make the answer a Clue, just a Clarification...!
    what are you talking about ?
    What ever the manufacture designates the year as, then that is what it is.
    If the manufacturer says the car is a 1945 model, then that is what it is.
    Does not matter if they took it to Aunt Betty;s farm in 1943 to show it off to Aunt Betty"s family.
    The car is what the manufacture says it is.
    1964 1/2 Mustang - A First Rate Introduction
    In 1964 production was in high gear for the newly designed 1965 Ford Mustang. The highly anticipated Ford Mustang was honored by being named the Indianapolis pace car of 1964 and Ford stepped it up to accommodate the rising status of their new design. A special convertible version was adapted as the pacer. It was manufactured in white with a blue stripe on the hood and trunk. Ford also made 230 extra pace cars, available in convertible and hard top. The 64 1/2 convertibles had a 289cid engine, and the hardtops came with the less powerful 260 V-8. Thirty five convertibles were sold to dealerships and 195 hardtops were given out in dealer contests held in April of 1964.
    It is hard to believe that the original Mustang, so popular and built in such big numbers, would have such low production in the most collectible engine and body style combination. But that’s what we see here in Jose Luis Abraham’s MCA Concours Gold 1964½ classic. This first year Mustang is so rare and hot it’s a Mustang and a half.
    It’s a K-code. It’s a four-speed. And, perhaps even more unusual, is the numeral “9” beneath “AXLE” on the original door data plate. This digit decodes a set of stump-pulling 4.11:1 gears in a “single track” (as opposed to an Equa-Lock) 9-inch rear end.
    1964 1/2 Mustang Facts
    Production
    MODEL AMOUNT
    Convertible, standard 28,833
    Coupe, standard 92,705
    Total 121,538
    Engine Options
    CID V CYL HP CODE
    170 1 6-cyl 101 U Code
    260 2 V-8 164 F Code
    289 4 V-8 210 D Code
    Transmission Options
    3-speed manual
    4-speed manual
    3-speed automatic
    Measurements
    US METRIC
    Wheelbase 108 in. 2,700 mm
    Length 181.6 in. 4,610 mm
    Width 68.2 in. 1,730 mm
    Height 51.2 in. 1,300 mm
    Curb wt-FB 2,606 lb. 1,182 kg.
    Curb wt-CP 2,556 lb. 1,159 kg.
    Original Prices
    MODEL PRICE
    Convertible, standard $2,557
    Coupe, standard $2,320
    Thanks to Farmer1 for this Contest, Thanks to Ryu for making this one possible by Donating Their Winning earlier and Thanks to Formuler and IPTVTalk...!
  3. #153
    1969 MG MGC Roadster
  4. #154
    Ambassador
    Aug 2018
    You are absolutely right but there are some where the vin description # does not match the year it was registered.
  5. #155
    Dec 2017
    1967 Excalibur SS Deluxe Roadster (model since mid-year 1966 for North America U.S.)
  6. #156
    Quote Originally Posted by Dodgeit1 View Post
    In those cases you would need to use a grinder and grind off the rivets that hold the ID tag and replace it with the correct tag so it can be registered.
    You would need a donor car for this and of course a grinder
    1966 Shelby Cobra 427
  8. #158
    Ambassador
    Aug 2018
    Lol Nope true story.I was looking at one the other day.I haven't seen many.I never really checked out the reason why they would be like that.Every digit matched but the 10th which is the year.Maybe they registered them at midnight.It might have been a Honda it was on.
  9. #159
    maybe the previous owner also owned a grinder
    Bullwhale
    the..1969 Nissan Fairlady Z
  1. Formuler Z8 Raffle 01/27/2019
  2. Formuler ZX 5G Raffle 01/09/2019
    Last Post: 01-17-2019, 12:25 PM
  3. Formuler Z7+ Raffle 01/01/2019 ( newest model available )
  4. Formuler Zx
    By crazed 9.6 in forum Formuler Zx
    Last Post: 09-15-2018, 03:57 PM
  5. Formuler Zx
    By sarkar in forum Formuler Zx
    Last Post: 07-29-2018, 03:15 AM
