Results 1 to 8 of 8
    Jan 2019
    Remote not working mag 322
    Using this mag 322 only for a week and now on the box it’s continuous blinking LEd blue light remote is not responding tried power on and off many times comes on main screen .
    If I point the remot it blinks on the box but if I remove the batteries from remote the led on box is not blinking
    Seeems like I have deleted the program on remote ?
    Please help
    try resetting the box or changing HDMI cable maybe.
    To reset from BIOS menu:
    Unplug the power from the Mag
    Then while pressing and holding the menu button on your remote control, reattach power and let it boot into the bios setup menu.
    Enter The BIOS.
    Choose “Def. Settings”.
    Press to the right.
    Confirm by pressing the “OK”.
    Select “Exit & Save” to save and exit.
    STB will reboot automatically.
    After you factory reset your box, dhcp and tftp loading is the default.
    To get back to booting correctly unplug and plug back in the box, then menu into bios again.
    Once there go to "Boot Mode" and right arrow to change it to "NAND" or NAND2"
    Then scroll down to "Exit & Save" and right arrow, then "OK" to save and reboot.
    Please note that any time you press the "OK" remote button in the bios, give it time to work because it takes a few seconds.
    - Frank Zappa
    Jan 2019
    Box is working fine only remote has a problem
    Shall I still do factory reset ?
    Jan 2019
    Again when I press any button on remote it’s not responding I tried those step but no response it comes to main screen with channels and all
    Quote Originally Posted by palaceus View Post
    batteries dead ?
    - Frank Zappa
    Jan 2019
    I changed batteries - no luck
    Then presses and hold ok and set up button and release - no luck
    Banned
    Nov 2017
    in front of pc
    Reset STB remote to the factory settings
    Press SETUP and OK button at same time and hold for 2 seconds. After 5 times blinking of right (red lighted) On/Off button the reset is done (all programmed sections of STB remote is reset).
    Jan 2019
    I did this
    But still no luck
