Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Mac id
    Mercenary floder2's Avatar
    yea
    llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllllllllllllllllllllllllllll lllllllllllllllllllllllllllllll
    Quote Originally Posted by floder2 View Post
    Very Informative Indeed...! and
    Nov 2015
    I am in the same boat. My mac id is locked and that's why I wanted to change its mac id. Would it work with other provider for same server?
    As long New MAC available on server and not being used then you should be able to use without any problem.🙂
    Nov 2015
    I changed mac id but it did not work. the server shows " it is still in use"
    Any solution and help please,
    Is there any software to check whether any mc id is in use or not?
    Looks like it might be "Hit and Miss" or "Hit and Go"...! Keep Changing it...! Or use the one that came with it to see if that one works and then try to change it again...! Lots of possible Digits...
    Try this Mac 00:1A:79
    Banned
    Nov 2017
    in front of pc
    Try this Mac 00:1A:79:C8:B5:E3
    you should have sent that in a pm
