Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 90
    Is it Completely Built already or does it require Putting it together" or even "Building and then Putting it together"...?!?
    Thanks to Farmer1 for the Contest...
    Thanks to the Formuler team for donating the Formuler Z7+...
    Thanks IPTVTalk for being here so all this could happen...
    Hint for today is that it has nothing to do with rc planes
    I am make my this one hard
    The more guesses the faster the hints come
    I can answer that with my next hint
    Mercenary floder2's Avatar
    yea
    Brew your own Beer.......!
    pontoon boat, Crestliner Retriever 1860, 90 HP Mercury Four-Stroke
    that's a nice boat I did start rafting at a young age
    AquaCraft Alligator Tours 30.3-Inch RTR Nitro RC Airboat
    Features:
    A Finished, Ready-to-Run Fiberglass Hull with Factory-Installed Foam Flotation, Prop Cage, Air Rudders and Water-Resistant Radio Box
    Tactic TTX205 2CH 27MHz AM with Adjustable Trim and Dual Rate
    Air-cooled SuperTigreĀ® .27 Engine W/Muffler & Setup DVD
    Display Stand/Carrier
    9x6 Pusher Prop
    180cc Elevated Fuel Tank
    Detailed Driver and Passenger Seats
    Includes:
    TTX205 2CH 27MHz AM
    Specifications:
    Length: 30.3in (770mm)
    Beam: 11.2in (285mm)
    Height: 14in (355mm)
    Weight: 6.3lb (2.86kg)
    Requirements:
    Transmitter/Receiver: 8 AA Batteries (Not Included)
    Fuel: 20% Nitro Fuel (Not Included)
    Other: Nitro Starter Racing Kit (Not Included)
    Heading down to AZ tomorrow so wont be on much for the next 3 days
    I will check in at night for sure
    Put your thinking caps on
    Honda Rubicon 500
    Specifications
    Collapse All
    Engine & Drivetrain
    Engine Type
    Liquid-cooled longitudinally mounted single-cylinder 4-stroke
    Displacement
    475 cc
    Bore & Stroke
    92 mm x 71.5 mm
    Compression Ratio
    9.5:1
    Valve Train
    OHV, 2 valves
    Fuel Delivery
    PGM-FI electronic fuel injection
    Transmission
    Fully automatic, five-speed, Dual-Clutch Transmission with Selectable Electric Shift (ESP) plus Dual-range sub-transmission and reverse
    Power Steering
    Standard
    Final Drive
    2WD/4WD; direct front and rear driveshafts with switchable 2WD/4WD and torque-sensing/locking front differential
    Chassis & Suspension
    Front Suspension
    Independent double-wishbone with adjustable hydraulic shocks; 185 mm (7.3 in.) travel
    Rear Suspension
    Independent dual arm with adjustable hydraulic shocks; 215 mm (8.5 in.) travel
    Additional Information
    Tires
    Front: 25 x 8 - 12 Rear: 25 x 10 - 12
    Brakes
    Front: dual 190 mm hydraulic discs Rear: 170 mm hydraulic disc
    Length
    2,147 mm (84.5 in.)
    Width
    1,205 mm (47.4 in.)
    Ground Clearance
    239 mm (9.4 in.)
    Seat Height
    909 mm (35.8 in.)
    Wheelbase
    1,292 mm (50.9 in.)
    Curb Weight
    325 kg (716 lbs.) including required fluids and full tank of gas - ready to ride
    Fuel Capacity
    14.7 litres, including 4.9-litre reserve
    Lightbulb
    Dune Buggy...
    https://www.wikihow.com/Build-a-Dune-Buggy
  1. Raffle for a Formuler Z8 09-26-2021 - big mac
    Last Post: 10-10-2021, 03:30 AM
  2. Formuler Z8 2/1/2019
    Last Post: 02-15-2019, 03:55 PM
  3. Formuler Z8 Raffle 01/27/2019
  4. Formuler Z7+ Raffle 01/01/2019 ( newest model available )
  5. Replies: 82
    Last Post: 01-02-2019, 03:19 AM
