Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 104
  1. #51
    use the MAC from the box, not from wireless MAC
    - Frank Zappa
  2. #52
    Apr 2015
    Thank you Crazed, but that does not work. The unusable MAC nr. also appears in the modem/router as attached device so it will also appear as so in the server. (I suppose)
  3. #53
    Banned
    Nov 2017
    in front of pc
    Quote Originally Posted by meijvogel View Post
    the mac you see in router is wireless mac
  4. #54
    Apr 2015
    thus it is denied access to the server because it is not a: 00:1A:79
  5. #55
    Banned
    Nov 2017
    in front of pc
    the server picks up the box mac
  6. #56
    iptv
    Quote Originally Posted by monty49 View Post
    I had the same problem so I went to the infomir site and downloaded multicast.When using multicast for the mag254 you have to change the ip address port on stream1 to 224.50.0.100:9000 and on stream2 to 224.50.0.101:9001.Input Bootstrap file in stream1 and imageupdate file in stream2. Takes about 20 minutes to complete then the box will reboot.
    Thanks monty49, I will try it and see if it works
  7. #57
    Try Rebooting the Router...!
  8. #58
    Apr 2015
    Thank you Dishuser and 4me2c. It is working perfectly on both providers now.
  9. #59
    yes I do
    when trying to download the no block file, it says my flash player needs to be updated. when I try to update the flash player with the download file, my anti virus (Norton) says it's not safe and delete the file. What so I do now?
  10. #60
    Shut off the antivirus before updating and try again.
  1. Cloudflare Blocking Again
    By Snowgoose in forum IPTV Private Server (Rocket)
    Last Post: 02-15-2020, 01:32 PM
  2. UK Blocking Portal?
    By bumper in forum IPTV Private Server (NFPS)
    Last Post: 01-26-2020, 02:13 AM
  3. iptv66 is blocking VPN connections
    By wag123 in forum IPTV Private Server (IPTV66)
    Last Post: 07-08-2017, 03:12 PM
  4. Flow is blocking
    By nelsonsylves in forum IPTV Private Server (NFPS)
    Last Post: 02-09-2016, 10:31 PM
  5. tsn reginal blocking
    By ronojow in forum aVOV TvOnline+
    Last Post: 02-03-2016, 04:13 AM
