I have the same problem. some channels are in slow motion, other channels are fine. I've tried uninstalling and re-installing but nothing helps.
now is this tv online or vod or apps that do that me i get it on apps like movie25 thats bad sometimes
Jusr TVOnline. Other apps work perfectly fine.
see tv online running fine checked all showtime working here with np
If your talking about the TV Online for the VIXO1 everything is NOT fine as mentioned above and in many other posts. If you view some channels in preview mode they look/sound fine but when you go to full screen the sound will go out of sync.
Have had same problem on certain channels, figured it was just because things are still being worked out. Will make a list of them
Switchon is right some channels in pic preview work ok then if u go full screen video seems to lag bit and audio out sync
Prob issues on there end
Checked a few channels, the following are out of sinc for me: A&e, H2, FX, TBS, WGN, FXX, HBO ZONE & HBO SIG./ probably more. Not complaining, just reporting. Things are still in the testing phase and i'm happy to have a ton of other channels that work just fine that i really have no time to watch.
HBO ZONE & HBO SIG- A&e-FX, TBS all work for me no freezing at all
