hi guys i got mag 410 android . can some one tell me which app is good to dowload watch iks rocket and what is portal address
IKS will not work on that mag410, but iPTV will.
Try setting up the server thru the Ministra Middleware that is onboard that mag410
If that does not work you may have to use an emulator.
http://iptvtalk.net/showthread.php?3...run-on-the-410
You would need an iptv code from the service in order to get the URL Portal address
All i need is portal adress for iptv stb emulator for iks rocket
It doesn't use normal portal adress. For stb emulator its different.
There are no guides here
I am NOT a "Bot"!
M3U Playlist editor >http://www.mediafire.com/file/q37ry8...ditor.zip/file
IPTVXtra >http://iptvtalk.net/showthread.php?3...s13-Repository
*Support the EPG Service >https://iptvextra.wixsite.com/iptv-extra
