Results 1 to 6 of 6
Thread: z7+ problem
    TV Addicted gotcha772's Avatar
    Oct 2017
    YES I DO
    z7+ problem
    I have a z7+ problem I need some help with , I turned on the box and it was booting normal and then a message popped up (enter eco stand by ) then the box shuts down and it does this every time any body know what I can do about this ? any help in the matter will of course be well received and thank you ...
    Oct 2017
    YES I DO
    I cant get my box to wake up , I know there is an update in there, I missed that fixes this issue but ive done the power cord reboot and menu reboot , ive tried a few things and I cant seem to wake it up ????
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Quote Originally Posted by gotcha772 View Post
    Until there is a fix in an update,
    Before you shutdown, make sure all programs are closed (exited out properly).
    The STB should then Startup normally.
    for now you can just unplug power for 10 seconds.
    Also, turn off "Eco Power Mode" under Settings>> System Settings
    Oct 2017
    YES I DO
    kens ; I cant get n2 the box at all ive done the unplug for longer then 10 sec. I cant get it to wake up if I can get in the box I can update it and turn off eco I have a vid of what its doing incase some one wants to view it
    Feb 2016
    yes i do -Y(not)
    you may have to do a hard reset using a USB stick with the recovery tool.
    See here >http://iptvtalk.net/showthread.php?3...-for-Z7-and-T2
    Oct 2017
    YES I DO
    I have tried that twice so far and nothing so far
  1. Big problem here
    By Texas Kid in forum IPTV Private Server (NFPS)
    Last Post: 12-02-2020, 09:37 PM
  2. mag 254 epg problem
    By polentone in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 08-23-2016, 10:43 PM
  3. vod problem
    By roadrunneric in forum aVOV VIXO 2
    Last Post: 07-30-2016, 12:15 AM
  4. problem
    By steven in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-20-2016, 12:24 AM
  5. Replies: 14
    Last Post: 09-18-2015, 09:40 PM
